October 11, 2024, 01:46:45 PM *
News: Please Help
Author Topic: Bike won't start, fuel delivery problem?  (Read 1078 times)
mattb
« on: July 13, 2008, 02:42:44 PM »
Hi,
My 2002 S4 won't start.  Cranks fine, even will turn over a bit once in awhile.  At first I thought I was just out of gas, the bike had sat overnight and I thought it knew it was really low on fuel, but next day, it wouldn't start.  I put some gas in it and still won't go...  Also, during this, I noticed that with the tank propped up, the bottom hose that goes from the tank to the engine is weeping a bit of gas from where it meets the tank.  I'm not sure if the line is cracked -- I think this is the return (smaller of the two hoses that go up towards the engine)...  Would this cause problems starting?
thx
Matt
Hedgehog
« Reply #1 on: July 13, 2008, 02:57:11 PM »
Leaky fuel hoses and fuel injection don't mix so well.
mattb
« Reply #2 on: July 13, 2008, 04:54:52 PM »
Grrrr -- it's actually not the hose, there is a crack around the base of the nipple that goes into the tank...
I just had the hinge on this tank welded and now it looks like I'm gonna have to have it welded up again ...  Should I just consider getting a newer plastic tank that won't have all of these issues?
m
For $50 you can touch my
« Reply #3 on: July 13, 2008, 07:55:06 PM »
m
I wouldn't-those tanks aren't cheap, and you'll end up sinking more into it than you'd like.
If you're going to replace it, I'd go with carbon fiber.
I would just have it welded again.
« Reply #4 on: July 14, 2008, 03:04:00 AM »
m
Did you coat the tank after welding?
you really should.
