Alternatives to expensive Ducati parts
Started by akmnstr, May 07, 2008, 09:43:08 AM
heatherp
Quote from: PizzaMonster on May 07, 2008, 08:10:38 PM
A bit of info from DUCATI OWNERS CLUB OF SOUTH AUSTRALIA on headlight replacement parts.  The pieces can also be found at a BMW dealership (R60 -R100 Boxers) or from a Bosch electrical supplier.  I haven't any personal experience with this but apparently Spidey has so a PM to him might be in order.
Headlight rim:    BMW p/n  63121356402
Glass Lens:        BMW p/n  63121358147      Bosch p/n   1305604904
Reflector Assy:   BMW p/n  63121355396      Bosch p/n   1305304903
I just did this due to stone cracking the lens after fitting lens protector.  (Rode for 18 months without one with no problems)
Using the Ducati/Bosch p/n can only get full assembly - local bike shop Aus$600, Ducati dealer Aus$400.
Using BMW/Bosch p/n lens only,  through local bike shop Aus $120.
Thanks to Spider's advice I took photos of the clip arrangement that hold the lens to the chrome rim before dismantling.
Works a treat.  And I am not putting the lens protector back on either.
squidwood
Yes I can confirm the fork seals from a GSXR will work .They are on my bike at the moment.I can also confirm that Ducati Seattle quoted me $140.00 for fork seals.I think they thought I just fell off the turnip wagon.I worked for Suzuki motorcycles 23 years ago, So i have quite a bit of experience with these 2 wheeled things called motorbikes.
Quote from: squidwood on March 14, 2009, 06:12:51 PM
what models are you referring to?
RBX QB
... I can also confirm that Ducati Seattle quoted me $140.00 for fork seals.I think they thought I just fell off the turnip wagon...
Tho, I called them about the lense glass, and the person who helped me told me of a "rumor" that there was a BMW part out there that fits without having to buy the whole assembly that the dealers sell. Hope Dave doesn't mind me saying that, but it's that kind of thing that keeps customers coming back, even if they don't ALWAYS buy parts there.
Mild jack, but this thread helped me find that BMW part number... so not a COMPLETE jack.
http://www.mikesxs.net/products-49.html#products
chain tool. make the beast with two backsing AWESOME! $20 does everything
Quote from: He Man on April 23, 2009, 08:53:40 PM
good link, does that remove press links or does it just rivet?
after you grind out out the mushroomed head on the rivet, you can use it to push the rivet out, ive read that this is the only case where it might be possile to snap the pin. after that you just adjust the tool to rivet and it'll know when to stop so you dont over rivet the chain and cause kinks. itll also press the plate in perfectly without curshing the oring.
clittelm750
Around $10 (includes shipping) from http://www.ekmpowershop2.com/ekmps/shops/vauxworld/index.asp Vaux-word - Part number: 90534902 Gets you a perfect match to replace the Oil pressure Switch - great guy to work with! I Suggest using paypal - My bank rejected the charge cuz it was a low $ amount and from the UK.
Part is for the GM Opel - has a different BAR setting - but the UK guys use 'em all the time and haven't had any problem - I've put on over 500 Miles with no issues on mine.
for long you live and high you fly but only if you ride the tide
sk8board
akmnstr
Quote from: clittelm750 on May 22, 2009, 08:07:35 AM
Do you know what Duc engines this fits?  I have an older M750 (1998) that needs this part.
Charles Darwin
clittelm750
Quote from: akmnstr on May 26, 2009, 08:56:50 AM
Ducati code 539.4.030.1A and 539.4.019.1A
akmnstr
Charles Darwin
brimo
Ride Height adjusting link, I know you can get the rose joints from just about any bearing supplier, but how about the tie rod?
From a story by RAT900
sk8board
http://stores.shop.ebay.co.uk/Vaux-World-com-4-ALL-VAUXHALL-PARTS Vaux-world - Part number: 90534902 Gets you a perfect match to replace the Oil pressure Switch - great guy to work with! I Suggest using paypal - My bank rejected the charge cuz it was a low $ amount and from the UK.
I received my oil pressure switch from Vaux-World today. It fit like an OEM part and it only cost me $12 with shipping to Ohio. Paid with Paypal on eBay.
The original Ducati part had been stamped "539.4.030.1A  0.3 - 0.6 bar" and the Opel part has been stamped "0.3 - 0.55 bar". So, it basically operates at the same pressures.
vwboomer
Anyone got a replacement for the S4R radiator? $1600 from the dealer - lists at 1900
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
