Alternatives to expensive Ducati parts
Started by akmnstr, May 07, 2008, 09:43:08 AM
DuciD03
#15
Brimbo Break Levers and Parts:
I copied this from another thread; it is should be here .... USA and Australian Refrences.
If you can buy direct from Brimbo it be less than Ducati dealership prices.
Re: snapped brake lever
phew. glad you told me.
so one more like this one?
http://www.yoyodyneti.com/ProductInfo.aspx?productid=110.2706.44
or this one?
http://cgi.ebay.com.au/Ducati-Brake-Lever-916-996-998-Monster-S4R-Multistrada_W0QQitemZ380032923642QQihZ025QQcategoryZ29705QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
or maybe even this one?
http://cgi.ebay.com.au/DUCATI-BRAKE-CLUTCH-LEVER-748-900-916-SS-MONSTER_W0QQitemZ290236584689QQihZ019QQcategoryZ102691QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hey Mostro, where are you at?
In Sydney, go to Gowanloch's, they would have them.
Normal levers without the dial $35 from memory. Dial levers I think are around $75.
An early reply mentioned Yoyodyne. Not so good for you; the shipping would kill the deal.
But Fred's a good source 'cause he's a Brembo dealer. So the message is, you can get a Brembo lever from a Brembo dealer for much less than you can get the same Brembo lever from a Ducati dealer (well, unless the Ducati dealer is sourcing them outside the Ducati
.... all the world is yours.
DesMotion
Chris Saraceni
Call me if you need something...
Manny
#18
Handguards for a Multistrada are $135ish from DP, but only $90 from KTM.  ;)
DrFunkyMD
#19
If you want to replace your mirrors with anything else that is not from Ducati, you will need to go to your closest Yamaha dealer and get a Yamaha mirror adaptor kit. It converts the 10mm left hand thread on the left mirror to a 10mm right hand thread. It also raises the right mirror to match the left mirror. It looks like this.
cbartlett419
wheel bearings for 25mm axles  6005-2RS (25 x 47 x 12)
Lifted from posts/TOB.  May fit other models, not sure about that.
M750:  Fuel filter -  Autozone 3047
M750:  Oil filter - Fram 6019
Even if you don't like the brands, you can at least cross reference at an auto parts store for your brand of choice ~
JM
Fuel pump for a 2006 620 - I was quoted $1,000.  Luckily it was replaced under warranty.
Chris Kelly of Ca Cycleworks (www.ca-cycleworks.com) has fuel pumps that are direct OEM replacement fuel pumps for $149.  "We've got dealer pricing so that shops can give out of warranty customers more realistic options."
CTKurt
I need to replace an injector on my 2001 900sie. I need a source. Way too expensive from Ducati.
Quote from: CTKurt on November 26, 2008, 10:51:00 AM
good question.  problem is that the EFI system on that model is 100% marelli, so you are stuck buying a compatible injector (size, electrical) or changing the whole setup.
probably only option is to find a used one on ebay.
DuciD03
Interchangeable Oil filters list
Thread started by meano_lover in Au 04 08; I was looking for a non OEM filter today and the auto store was totally confused; I would have gone to a Motorcycle store but there all closed on Sunday.
From MMacky
Here is the most complete list I could find.  I last used the NAPA filter, and at that time it was made by Mann of Germany.  Excellent quality for about $7.
US available: (exact)
  K & N KN-153
  Perf-Form DUC-1
  Athena FFP011 (Ducati OEM)
  Scott's Performance (permanent washable replacement)
US available: (near exact, fits fine.  length may vary)
Fram PH6074 (was PH2839, PH2864A)
  Purolator ML16829C (was FC 103 or OC 5)
  AC Delco FX0011 (was X4A)
  Motorcraft EFL 47
  NAPA: 1352 (1352NAPA and 551352 on the box)
Non US:
  Champion H101
  Cooper Z64
  Powertrain FL125
  Fiaam FT4654, FT 4847 or PA7059
  Purflux LS187
  Halfords HOF216
  Tecafilter Ref OC5
  Technocar R12, R72, R434
  Knecht OC 5 (equivalent to Ducati #065149960 and #090549960)
  TJ FB2094
  Mann & H W712/9, W712/11
  Unipart GFE 201
Good cross reference list I ran across a long time ago - glad I kept it now.
Grumby
Motorcraft EFL 47
Champion H101
Cooper Z64
Powertrain FL125
Purflux LS187
Halfords HOF216
Tecafilter Ref OC5
K & N KN-153
Knecht OC 5 (equivalent to Ducati #065149960 and #090549960)   TJ FB2094
Unipart GFE 201
Desmo Demon
I switched to using the K&N simply for the welded nut on the end of it. It makes removal sooooo easy.
Here's an interesting tidbit......if you are in a crunch and on a trip somewhere and NEED a filter but cannot find one, go to the local Harley-Davidson dealer.......yes, the local Harley dealer......There are certain mid-80's Harleys that use similar filters. I use the K&N 153 on my '85 FXEF, also.
(So, if you want a chrome filter for your Duc, you can use K&N 172C)
The differences are that the KN-153 has a 1.45 psi higher pressure relief valve and is 0.209" (6mm) longer than the KN-172C. The KN-172C also does not have an anti drain back valve (so an OEM Harley filter should have similar specs to the KN-172C). The last time I bought a filter from the HD dealer, the black one was $5-$6. I think the old 100k+ mile engine can use the higher pressure that the KN-153 supplies, though
KN-153 specs...
Product Style: Oil Filters
Height: 3.331 in (85 mm)
Outside Diameter: 3.059 in (78 mm)
Thread Inside Diameter: M16 x 1.5
PSI Relief Valve: 15.08
Anti Drain Back Valve: Yes
Style: Canister
Weight: 0.7 lb (0.3 kg)
Product Box Length: 3.25 in (83 mm)
Product Box Width: 3.25 in (83 mm)
Product Box Height: 3.5 in (89 mm)
KN-172C specs...
Height: 3.122 in (79 mm)
PSI Relief Valve: 13.63
Anti Drain Back Valve: No
Style: Canister
Finish: Chrome
Weight: 0.6 lb (0.3 kg)
Product Box Height: 3.25 in (83 mm)
greenohawk69
Quote from: ducvet on May 07, 2008, 06:54:35 PM
kawasaki key
starts my kawasaki so I don't need any expensive ducati parts :e:v
Do you know which Kawasaki key to use?  I stopped by the Kawasaki dealer and the person said there are 4 different types.
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
minnesotamonster
Quote from: greenohawk69 on December 31, 2008, 09:29:24 AM
Psst....I think that was a joke.... ;)
2004 S4R
1998 Honda F3 (Track)
2001 M600 (Now the Wife's)
No joke, there is a Kaw, Alfa and Fiat blank that will work.  A real lock smith should be able to hook you up.
