Spring reccomendation
Started by Howie, January 13, 2015, 05:06:28 AM
My '04 M1000 S  is getting an Ohlins S46PR1C1S shock.  I weigh 145 without gear.  What spring do I need?
Doh!  Good idea!  Don't want to bother him so I will send him an email.
Thanks!
Quote from: howie on January 13, 2015, 05:15:09 AM
Thanks!
He lives on the phone. ;)
Just call after 9 when he gets to the shop. He can probably supply it too.
Can't hurt to ask.
MonsterHPD
Quote from: howie on January 13, 2015, 05:06:28 AM
I weight slightly less, ride mostly 1-up, and use a 95N/mm spring on one bike, and 100N/mm on the other (Monster 900-02 and 800-03; same frame as you have).
I've tried an 85N/mm once, definitely too soft. 100N/mm would be my recommendation.
Monster 900-2002 (sold, alive and well in the UK), 749R / 1100 HYM combo for track days, wifes / my Monster Dark 800-2003 (not entirely "Dark" anymore and a personal favourite) , 50% of 900SSie -2000 track bike for rainy days-now with tuned ST2 motor and Microtec ECU. Also parked due to having been T-boned on track.
Thanks.  I should have mentioned mostly shitty condition New York street riding.  Same recommendation?
1.21GW
#6
My recommendation for the spring?  Update your spell check function.   ;)
Meanwhile, in other news, I need to arrange a meet up to get that helmet case from you.  Trip is 2.5 weeks away...
MonsterHPD
Quote from: howie on January 13, 2015, 09:33:43 AM
Well, for me I'd stick with the springs I have, but in the end only testing will tell. I suppose a well-established suspension shop could swap the spring for you for a reasonable fee, should you not be happy with the first shot.  For street riding I personally prefer slightly softer springs with slightly more pre-load, but too soft does of course does not work at all.
Quote from: 1.21GW on January 13, 2015, 09:59:34 AM
Got it correct once, wrong once.  Batting 500, that ain't bad :P
Didn't know you wanted the bag.  You could have had it Friday, we were in Brooklyn.  Wanna make a trip up to the Bronx?
Quote from: MonsterHPD on January 13, 2015, 10:25:47 AM
Thank you.  Just what I was looking for.
I prefer a slightly stiffer spring with less pre-load...go figure.
My experience is the more preload on a spring the harsher the ride, particularly on the kinds of roads we have in the northeast.
I'd go along with the 100 N/mm spring recommendation for you, Howie.
I'd ask Eric about taking out some compression damping prior to putting the shock on the bike.
IMO:
The Ohlins seem to be set up with the firm damping/soft spring philosophy.
Good for racetrack, but not so compliant on sharp-edge bumps in the real world.
Both of my Ohlins-equipped bikes ('02 S4 and '98 M750) I've got the compression damping adjust at full soft, or as soft as I can go without it getting wallowy.
The compression damping adjust is primarily effective at low shaft speed, so 'fixing' a high-speed damping issue with it is a compromise.
Both shocks will get shims removed from the compression stacks the next time they're serviced.
MonsterHPD
Quote from: ducpainter on January 13, 2015, 10:44:43 AM
I suppose we're talking nuances here. If the softer and stiffer springs are pre-loaded to give the same initial force, the softer spring will require less force for the same wheel travel than the stiffer, which, on the other hand, will provide more reserve. .
However, as noted above, too soft is absoutely bad, and too soft a spring might allow the travel to reach massively into the bump rubber, I suppose that would give a harsh suspension action on big bumps.
MonsterHPD
Quote from: Speeddog on January 13, 2015, 11:34:19 AM
I did that to my M900 shock last year, and have just done so for the M800 now. Big improvement!
Quote from: MonsterHPD on January 13, 2015, 11:37:33 AM
Agreed, except the preload required to maintain correct sag on a softer spring, and the force to initiate movement might very well exceed the force to get the stiffer spring moving at the preload required to maintain sag. Once moving the rate is the rate.
My old DU-440 seems to damp fine with a stiffer spring Nick.
