synching carbs
Started by truckinduc, July 13, 2008, 09:12:43 PM
truckinduc
Well guys im in desperate need of synching my carbs once i get my bike back together. Anyone have any tips, pointers?
Hedgehog
Quote from: truckinduc on July 13, 2008, 09:12:43 PM
Get a mercury manometer.  Go for a ride to warm the engine up.  Hook two of the hoses from the manometer up to the vacuum ports.  Start the bike.  Adjust the balance adjuster (not the idle speed adjuster) until the columns of mercury are the same height.  If the sync was really bad, you may have to also adjust the idle speed.
NOTE: Be very careful not to burn your arm on the exhaust pipe.  If you do you may have to go to the ER 2 days later for IV antibiotics.  (Ask me how I know.)
NOTE 2: Mercury is poisonous if you're exposed to it in much larger concentrations than you'll see with even a modicum of care using mercury manometer.  Just don't let your kids or pets drink it.
desmopr
#2
http://www.powerchutes.com/manometer.asp  This very cheap method works and is the one I used on my M750.
And yes I have also burned myself doing this and have a small scar to prove it  >:(
2001 Monster 750 (SOLD)
truckinduc
i just got out of the hospital where i had 4 days of IV antibiotics.
Quote from: desmopr on July 13, 2008, 09:23:07 PM
-----------snip----------
That setup will work just fine.
Use whatever size hose fits over the fittings on your manifolds.
meano_lover
www.ducatisuite.com/carbsynch.html
aka- use a vacuum gauge and adjust the synch screw as needed.
'97 m900; stage 2 carbs, filter pods, remus carbon exhaust
