clicking when giving gas...
Started by yellowjacket, July 13, 2008, 10:38:34 PM
yellowjacket
hey all, i have a 03 M800 and whenever i'm in second or third (usually when I shift into it), and gave gas, sporadically, I feel a "click" and a slight pause when it click.  It doesn't happen everytime but usually happens when shifting into second gear.  The "click" is hard to describe, it doesn't really affect the performance of my riding but I do feel it distinctly (almost like there's a skipping in the transmission).  Is this unusual?  Would appreciate any and all input.  TIA
03 M800S IE- my first ever bike.
How long ago were your valves done, and how many miles on your bike.
What engine mods do you have?
Cider
That sounds like the typical backfire problem.  Speeddog--did you adjust your throttle position sensor as per the thread on this topic a couple months ago?
EEL
#3
+1 to speeddog's comments. I had this problem, valve adjustment issue, your closers are loose.
chixstrip
Euro 3 emission standard is the devil
Quote from: Cider on July 14, 2008, 06:07:44 AM
I haven't messed with my S4, no.
Cider
Shucks.  I was wondering if that would work.
Hedgehog
Quote from: yellowjacket on July 13, 2008, 10:38:34 PM
Kind of like a balloon popping at the intakes?  You might want to check to see if the rubber gas line in the tank is cracked and bleeding off fuel pressure, if the other suggestions get you nowhere.
yellowjacket
Quote from: Speeddog on July 13, 2008, 11:30:24 PM
I recently bought the bike in April of this year with 6300 on it.  The previous owner got the 6k serivce done at Seattle Ducati.  My bike now has 7300 on it and as far as I know no engine mods.
Dragsterhund
My 03 800 does the same thing, only its usually when I'm holding the engine at a constant RPM. I've been told everything from a bad throttle position sensor spitting back wierd values to lean fueling. I'm ordering a PCIII to see if that fixes the issue (and because I've been wanting one for a while).
Is this different than the surging issue that has plagued so many S2Rs?
2003 Ducati Monster 800S i.e.
1999 Ducati 748S Track Bike
2011 Ducati 848 Track Bike (Ex Jake Holden AMA DSB bike)
1967 Ducati Monza 250
2008 Yamaha TTR 125
1973 Honda CB450 (Sold)
1972 Honda CB450 (Sold)
2002 Suzuki SV650 Track Bike (SOLD!)
1994 Kawasaki EX500 (SOLD!)
