February 11, 2025, 03:51:59 PM
LW Flywheel
Topic: LW Flywheel (Read 3252 times)
hackers2r
LW Flywheel
January 29, 2015, 06:00:07 AM »
I am considering this mod for my S2R. What is the general consensus for mainly street riding? I believe I've found a DP one for the same price as the Nichols one, any real preference? Thanks
Rudemouthsky
Autonomous red and black
No gods and no masters
Re: LW Flywheel
January 29, 2015, 06:13:38 AM »
This is one of those subjects that have generated a mountain of discussion via the search function.
I know I was kept busy when researching whether or not to use one with my M944SS build. I ended up going with the Nichols but would probably opt for a lightened stock flywheel over the ultra light Nichols if I had a do-over. It's an extremely dramatic mod for a street bike.
Do you like wheelies or not?
Feral 859
Re: LW Flywheel
January 29, 2015, 06:18:45 AM »
Have the stock one lightened.
hackers2r
Re: LW Flywheel
January 29, 2015, 07:08:29 AM »
If there were someone close to me, I would have mine lightened. What's your reasoning on going with a slightly heavier one than the Nichols? And is there any difference between the DP offering and the Nichols and a lightened OEM?
Rudemouthsky
Re: LW Flywheel
January 29, 2015, 07:21:47 AM »
Quote from: hackers2r on January 29, 2015, 07:08:29 AM
Fast Frank sells lightened OE flywheels with no core exchange necessary last I checked.
Re: LW Flywheel
January 29, 2015, 08:42:33 AM »
Quote from: kopfjäger on January 29, 2015, 06:18:45 AM
This...
thorn14
Re: LW Flywheel
January 29, 2015, 09:10:07 AM »
I sent my stock one out to Fox Performance to get lightened, then decided I wanted it lighter and got the sbk alternator adapter from Fast Frank Racing. Probably lost about the same weight as the Nichols, for more money. But, now I have a steel flywheel.
M620
turned
M800
but then back to M620 after the M800 died at 110k, and now to Multi 1000.
hackers2r
Re: LW Flywheel
January 29, 2015, 09:20:08 AM »
Sooooo...from what I can decipher, the OEM lightened one is steel, and the Nichols and DP are aluminum. Can anyone educate me as to why it is preferable to keep the lightened steel vs the aluminum?
Enjoying the ride
Re: LW Flywheel
January 29, 2015, 09:27:19 AM »
this, to possibly avoid this,
20140304_104802
by
, on Flickr
20140304_102200
by
, on Flickr
20140304_102005
by
, on Flickr
20140311_151636
by
, on Flickr
hackers2r
Re: LW Flywheel
January 29, 2015, 09:35:09 AM »
What is that a result of if I may ask?
Enjoying the ride
Re: LW Flywheel
January 29, 2015, 09:39:24 AM »
the nut came loose . . . when installed I used Ducati specs, these were later revised and torque was increased to 270Nm instead of 190Nm . . . it was sweet, but now, I will go back to OEM since no more DP lightened flywheels available . . . if I get an OEM one, might send to ML for lightening to my specs . . . In the future to come . . .
and a lot of $$$ has gone into repairing it . . .a year after and between having no time and taking care of customers bikes, . . result is, bike is still on stands . ..
Re: LW Flywheel
January 29, 2015, 09:43:07 AM »
They'll do it even if the nut isn't loose.
My theory is the aluminum expands and the flywheel can move back and forth on the splines the amount of the clearance between the two parts.
The aluminum can't take the battering.
Go with a lightened steel flywheel.
Enjoying the ride
Re: LW Flywheel
January 29, 2015, 09:45:02 AM »
that was my case . . . I did hear about someone having similar issue of damage and nut WAS tightened . . .
MotoPsycho
General Nuisance and a
My Dream, my rules !
Re: LW Flywheel
January 29, 2015, 10:09:17 AM »
That makes me want to take the case off of my bike and look now. I've had a nichols for going on 7 years and never saw any shavings in the oil. But considering I torqued to 150ft/lbs with red loc-tite, I never expected to have troubles.
Enjoying the ride
Re: LW Flywheel
Reply #14 on:
January 29, 2015, 10:19:08 AM »
Here are the torques:
ALL, except below: 270N\m with Loctite 128455
Panigale screw 160N\m with grease AGIP GR SM 2
MTS/DIAVEL/M1200 330N\m with Loctite 128455
