January 09, 2025, 07:49:45 PM *
Pages: [1] 2   Go Down
Author Topic: Input: Mods for Tricolore S4RS  (Read 5952 times)
beelzebub
« on: July 14, 2008, 07:23:03 AM »
OK - I've done a couple small mods so far and was looking to get some input on what comes next.
Done:
- CRG lanesplitter/blindsight
- Speedymoto pressure plate & cover
- Homemade mini-tail chop (removed fender, put on a couple brackets to move plate back)
- Destickerification & antireflectorizing
A current pic:
Here is where I could use some input:
- I hate the plastic tail & floppy plastic turn signals (F&R). I really don't want to cut the frame but I'd like a new tail (carbon?) and signals - any suggestions? FYI,  I will eventually go with a full termi system and don't like the look of a full chop with the long pipes...
- I want to take the passenger pegs off but I can't bust through the red loctite the factory thought was necessary to put on there. Tried a soldering iron to heat the bolt but no luck. Don't want to take a torch down there either - any suggestions?
- Carbon hugger for the rear.
- Other suggestions?
corey
'06 Tang/Black S2R800
« Reply #1 on: July 14, 2008, 07:59:16 AM »
I don't have one, but i want one:
http://www.monsterparts.com/pc/ZU-C010EDM/Bodywork-Carbon/ZU-C010EDM.html
Short tail from carbonworld.de i believe. Monsterparts is out of stock i guess...
beelzebub
« Reply #2 on: July 14, 2008, 08:43:02 AM »
I like the short tail...found it @ shopducati.com for $341.99
http://www.shopducati.com/scs_search_results.htm?search=96949002B&imageField.x=41&imageField.y=12
...and it's in stock according to an email reply I just received!
ODrides
2006 S2R 1000, 2003 998
« Reply #3 on: July 14, 2008, 09:31:48 AM »
Can't imagine enough torque and good hex wrench wouldn't turn those passenger peg bolts.
Check to make sure your licence plate won't hit your tire at full compression.
jesse370
« Reply #4 on: July 14, 2008, 10:47:36 AM »
DP performance kit.
it really really really transforms the bike into a animal, its just loony
White S4Rs | Ducati Performance Chip | Termi's | Hyperpro side mount damper | Motowheels MW-7000 Slipper | Billet Clutch Cover |  Speedymoto Ti Spring Caps | Speedymoto Stainless Springs | STM Frame Plugs | Ducati Performance Seat | CRG Roll-A-Clicks
mxwinky
'08 S4RS Tricolore #187, '95 900SS SP, MTS 1000S
« Reply #5 on: July 14, 2008, 07:01:27 PM »
Congrats on a fantastic bike.  I think I'm finally done modding my Tricolore, and here are my recommendations:
Carbon rear hugger, carbon chain guards, carbon heel guards, carbon sprocket cover - just finished up what the factory left off here.
Shorty carbon tail from Monster Parts - basically the same as the DP part but for much less $$$.  I used the stock turnsignals, but DP (and others) offer smaller turnsignals that would look a bit tidier.  Personal preference here.
Destickerification & removal of reflectors from front forks.
Removed passenger pegs as soon as I got it home.  Get out a breaker bar and give it a good tug; the bolts will come out.
And the mod of all mods - full Termi kit from DP.  It comes with its own dedicated ECU which really makes the bike come alive and gets rid of the excessive Euro-3 leanness and resultant airbox popping and occasional flameouts.  The bike runs flawlessly with this setup; absolutely no complaints.  In back-to-back tests I decided to leave in the baffles because it gave me better low-end snap while keeping the sound within reason.  Again, personal preference here, but overall I think the full system is a must-do.  It looks fantastic, sounds great, and runs like it's meant to - like a scalded ape!  Since I didn't chop the tail but only added the shorty carbon bit, the exhaust doesn't stick out in a gangly fashion past the rear of the bike, which IMO keeps the look sharp.
While in the shop for the exhaust/ECU install the tech removed the ugly emissions canister too.  Looks much better.
What else?  Hmmm, let's see . . . Oh yeah, Speedymoto frame sliders.  Looks good and adds a bit of protection.  Hey, the radiator alone is $1600 so I'll take whatever protection I can get!
And now I've got over 2000 miles on it and the smiles never cease.  Damn fine bike!
beelzebub
« Reply #6 on: July 15, 2008, 03:57:18 AM »
thanks for the advice guys....i'll check the plate clearance tonight. Then bust out the breaker bar and try again.
As for the DP Termi kit - that is on the list but I've got to wait for the $$$.
yamifixer
« Reply #7 on: July 15, 2008, 08:23:14 AM »
BEST MOD POSSIBLE. PUT MY NAME ON THE TITLE.
Valve Springs are EVIL
hypurone
« Reply #8 on: July 15, 2008, 09:17:03 AM »
Done:
A current pic:
There is a tool called an impact driver. Usually a 3/8" but can be found in 1/2". 3/8" is usually sufficient and you can use a step up adapter if needed for using 1/2" sockets etc. The tool accepts socket driven bits or sockets themselves. This coupled with the hex or socket you need and a hammer, and you are good to go...
LA
The Sleek Black Beauty
« Reply #9 on: July 15, 2008, 05:00:49 PM »
Don 't do ANY cosmetic mods. Your bike is a cosmetic tour de force as delivered.  Ride the bike.
The ONLY cheap mod and the most effective is a 14 tooth front sprocket. 6th gear is useless otherwise.
The Termi "race" kit is a MUST do - not an option. It makes the bike what the designer/manufacturer meant it to be, rather than what DOT/EPA would allow. The bike is a relative "piece of shit" without it.
Look on the moto-one site. The baffles IN reduces torque in the most important (low part) of the power range.
If you plan to ride the bike hard at all a steering damper is very useful mod. I was a naysayer on this, but am a card carrying convert.
LA
factorPlayer
« Reply #10 on: July 16, 2008, 12:03:23 AM »
There appears to be some type of weird contraption perched on your bars  Huh?
beelzebub
« Reply #11 on: July 16, 2008, 05:43:17 AM »
OK - I managed to beat the passenger peg bolts into submission so those are off now.
Unless someone wants to front me the $3k for the termi kit - it has to wait.
As for the 'weird contraption' on the bars - I took the bike on a road trip for a couple of days on some (way) back roads. It looks better than an empty tank of gas but YRMV.
CDawg
S4RS
« Reply #12 on: July 16, 2008, 05:46:24 AM »
I think you mean it's a Garmin Zumo
LA
« Reply #13 on: July 16, 2008, 09:31:50 AM »
I'm not made of money either. Cry
Check around. I paid $2100 for my kit at the time of purchase and one hour shop time ($80) for install.
LA
factorPlayer
« Reply #14 on: July 16, 2008, 10:01:18 AM »
It's like a wart on a model's ass  Tongue
Pages: [1] 2   Go Up
