Will these fit for stock rearsets?? (reverse shifter and brake lever)
Started by mr.freezer, February 24, 2015, 06:31:42 AM
Rudemouthsky
Quote from: mr.freezer on February 27, 2015, 11:08:10 AM
If SSRs would fit, these would fit too. 'cos these look exactly the same as SSRs
They look the same because they are...SSR is mostly branded CN made parts.
mr.freezer
the las in line... these are not for monster 620... as you can see, these brake levers are for bike with brake lever mounted on engine... M620 has brake lever mounted on rear set..
 :'(    . . .  just trying to help . . . as said I had previously used SSR pedals and looked exactly as the last ones I linked . . .
