Will these fit for stock rearsets?? (reverse shifter and brake lever)
Started by mr.freezer, February 24, 2015, 06:31:42 AM
mr.freezer
Hi Guys.. I have just wondered if these fit my monster 620 with stock rearsets... I think there won't be problem with shifter.. But it does not look like brake lever would fit... So what do you think??
as per the seller they should fit (they do look like the ones I once had). . . try visiting ssr's web site, if they look the same and these are exactly the same, then pull the trigger . . . if not, try one of our sponsors . . .
Yeah, I was just thinking these look like SSR clones.
The replace the stock and attach directly to the splined shaft for the shifter, so that's how they convert to GP shift. The catch is you lose the fine adjustment a threaded rod linkage gives you. Yes they do have the eccentric adjust for the toe  - but with single eccentrics, up/down adjustment also means fore/aft adjustment.
mr.freezer
I know that shifter will work... I am afraid of fitting brake lever... it is not curved as original...
Quote from: mr.freezer on February 26, 2015, 09:58:20 AM
if not mistaken, shifter is long one, brake short one and it does have a curve . . .
mr.freezer
I know that short one is brake lever, but when I put pictures of original brake lever and this one side by side it seems not to look very similar... especially mounts for push rod and rod for brake switch...
Quote from: mr.freezer on February 27, 2015, 02:33:57 AM
Ok . .  in said case, as the saying goes "if in doubt, don't" . . . if these were the SSR ones I would then be 100% but your last comment has made me doubt . . .
mr.freezer
If SSRs would fit, these would fit too. 'cos these look exactly the same as SSRs
mr.freezer
I have just received the answer from the seller, who wrote that it does not fit to Monster 620.. So guys... another question is, Where to find billet shifter and rear brake lever for stock rearsets??? or really cheap aftermarket rearsets..
Quote from: mr.freezer on February 28, 2015, 12:54:15 AM
SSR . . . . or try http://www.mc-motoparts.com/motorcycles-bike-model/ducati/ducati-monster-620-ie-2003-2006/?sort=featured&page=3
mr.freezer
I have searched.. I can not find any brake lever... shift lever are available everywhere... but no brake levers...  [bang]
