October 10, 2024, 01:21:42 PM
Coming up on 15k tuneup need some info
Topic: Coming up on 15k tuneup need some info (Read 934 times)
EEL
July 14, 2008, 08:16:47 AM »
From my previous thread posts some on you may have noticed that I have a cheap (and sometimes lazy) bastard.
That being said, I'm coming up on a 15k valve adjust for my S2R. I have an EMS shim kit but knowing my luck, I'm positive that I'll end up having all the closer shims on my S2R about the same dimension. Since the EMS kit only comes with one shim per specified thickness, I'll be screwed.
So I had a thought. Let me know if this makes sense.
If I spend the 150 bucks on some MBP collets, I'll be able to add about 3 thousandths of the overall closer shim thickness. Most likely this will be more than the closer gap and all I'll have to do is sand down my existing shims. Instead of measuring shims, placing an order with EMS and having my bike down for a week. At my 7.5k check my closers were off by about .0015 of an inch. So I know they're getting looser.
Someone needs to confirm that there's no flaw in the logic.
Last Edit: July 14, 2008, 09:25:13 AM by EEL
Re: Coming up on 15k tuneup need some info
July 14, 2008, 08:22:09 AM »
S2R 800 or S2R1k, and which year?
Your closer clearances were .015" at 7500 miles?
EEL
July 14, 2008, 09:22:59 AM »
S2R 800 05
OOPS!! Forgot a zero there. .0015" . One of them was the others were a tad less, I just gave the worst case scenario. I just figured I rode it a bit harder than most...
Sorry I modified the original post before I scared others..
Last Edit: July 14, 2008, 09:24:42 AM by EEL
clubhousemotorsports
July 14, 2008, 04:31:47 PM »
The only flaw I see is that for the cost of the collets you could buy a lifetime supply of shims for the bike well probably 18000 miles worth. [moto]
EEL
July 14, 2008, 09:48:31 PM »
In this case laziness > cheap nature. 125 + shipping for longer service intervals and no downtime for the bike...
