Old car build thread
Started by Popeye the Sailor, March 11, 2015, 11:26:08 PM
yamifixer
I commend you for admitting it was over your head at some point and getting help. I did a '69 Camaro and kept telling myself I could do it. I was wrong. cost more to fix what I screwed up than it would have to have it done right up front.
keep the photos coming. I'm loving them. cheers
Valve Springs are EVIL
Picked up a pedal car for the boy.
Brought it up to Nate's  ;D
Sealer
I should be able to wrap it up soon.
A huge thanks to Nate for showing me all the shit I was doing wrong.
yamifixer
that is pretty sweet (Peddle car) I have the same one that somehow survived my and my brothers childhood sitting in my garage in very pore shape. Another project i have yet to get to.....
Well Dave???
Screaming for stripes that car is! [thumbsup]
Got some striping supplies you'd recommend, Steve?
Many adventures were had last summer:
Yes, he's too big for it.
He's even bigger this year but convinced he fits.
Back to the Falcon.
So the trunk lid had separated-the outer skin was no longer held in place by the inner bit. So none of it....lined up with the rest of the body. I welded a bunch of tabs that bridged the gap:
and had a buddy hold one side where it should be and tacked the other end of the tab so it would line up with the body, and we worked our way over.
Fabbed up some brackets:
Mounted the rear seats:
Front seats need to be mounted next, then the new column/steering wheel etc.
Hey, look at the shitty dash.
We'll come back to that. I'm as steady as an epileptic squirrel.
See that back there? Weld it. Don't set it on fire.
Hey look. Safety all around.
Also ugly. make the beast with two backs me they kill the flow. But you know-not eating dashboard? Kinda cool. I don't even know.
In other news I'll never forgive my wife for wanting exterior door handles. Every other bit of trim and what not has been removed. Except for those.
It's the worst thing she's ever done, and she tossed my Ducati on the pavement.
Say hi to my buddy Pat, who just discovered there was no candy.
Hey look-a collapsible intermediate shaft. Now we can go from totally unsafe to less totally unsafe.
A tilt column and a smaller steering wheel means we both fit better.
Stu will object to the wheel change, but c'est la vie.
I need to cut off the old steering shaft next and I like to sleep on these things.
That and the shaft needs to get cut on the engine side of the firewall.
Which I can sorts of get my pneumatic cutting tool to reach, but I have to thread it way down and when I get it in the right spot....the button ends up on the passenger side of the firewall.  [bang]
So...I'll be waiting for help on that one.
Then I need to weld on the lower joint and figure out the height of the drops/install the column mounts and then I'm good to go.
The whole mess is too long but that intermediate shaft can be trimmed.
__________________
So anyway. Old shaft is ~33" and change.
New column, intermediate shaft, u-joints....is....42".
My math may have been off.
I can cut enough out of the intermediate shaft to make the existing stuff work, but that lessens the amount of collapsibility we're left with-I'd like to avoid that.
New column is 16", and they make a 12", so....one has been ordered.
I couldn't access the steering shaft to cut it so...pulled the pitman arm and the bolts that hold the box on.
It doesn't come out-not through the firewall, can't be dropped out or raised up through the engine compartment. Cut the shaft off and removed the valve cover and I could get it out the top and cut the shaft to the right length.
Next will be mockup when the new column comes, so I can orient the wheel to be centered when the wheels are.
