Old car build thread
Started by Popeye the Sailor, March 11, 2015, 11:26:08 PM
Maybe something should go behind this after I clean it? Weld thru primer?
Quote from: Popeye the Sailor on March 04, 2024, 09:55:21 AM
I may have put a few holes in it that I wasn't too proud of.
Due to proper planning, I practiced with the more visible driver's side and not the other side...or the dented to hell Falcon outside.
Pretty sure I warned you about that.
Quote from: ducpainter on March 04, 2024, 02:41:37 PM
You sure did.
Probably only one of us was surprised.
Probably not the person who picks up the phone when I call with the greeting of "what'd you make the beast with two backs up now?"  [laugh]
Quote from: Popeye the Sailor on March 04, 2024, 04:25:08 PM
You sure did.
Is that his traditional greeting when you call him?
I can picture this.
Quote from: Monsterlover on March 04, 2024, 04:27:21 PM
I can picture this.
Yes.
I'd object to it but....I'm calling because I make the beast with two backsed something up.
Quote from: Popeye the Sailor on March 04, 2024, 04:53:39 PM
Yes.
I learned to call before I make the beast with two backs something up ;D
Quote from: Monsterlover on March 04, 2024, 05:03:16 PM
I'll send you a paint gun.
Quote from: Popeye the Sailor on March 04, 2024, 05:32:05 PM
You've seen what I can do with one of those.   ;)
I have all four doors, the hood, and the trunk as aligned as they''ll ever get. Possibly better than factory.
I successfully managed to use the Rust Mort Nate recommended to ML.
Next up, I should prime the two panels that are prime ready. Nate, you said a urethane over Rust Mort or can I get away with HOK KD3000 (which I have)?
https://www.houseofkolor.com/products/primers/?ref=footer
Quote from: Popeye the Sailor on October 02, 2024, 04:04:32 PM
No epoxy over a product that contains phosphoric acid. It'll fall off in sheets.
Quote from: ducpainter on October 03, 2024, 05:56:35 PM
Thread jack... some spots on my carbon wheels are now without any clear paint. Must the epoxy be prepped in any soecial way before new clear?
Quote from: stopintime on October 04, 2024, 07:30:28 AM
Your wheels are likely coated with a urethane, not epoxy. Most qualified painters will know how to deal with things.
