putting my bike together...please help me out along the way..
Started by Rudemouthsky, March 16, 2015, 03:27:56 AM
Rudemouthsky
Did something dumb.
Poured like a shot glass sized amount of gas in the carbs bc I was eager to her her run. And she fired up alright...and sounded glorious for about 2 seconds. Noticed I was leaking oil at all 4 oil cooler connection points so I tightened everything up, topped off the oil, tried again (bc I'm stupid and impatient like that) and nothing. Thought maybe I flooded it so I took the plugs out to check, thought I might have smelled gas on em, swapped em out...tried again with starter fluid still no go. Now I have no spark on either cylinder. What the heck did I do?
Rudemouthsky
#92
Quote from: ducpainter on April 30, 2015, 05:56:58 PM
Are you running stock ignitors or an Ignitek?
Ignitek...
Also...why can't I find step by step instructions for wiring up the coils and ignitors anywhere in my manuals? I have both a Haynes and LT Synders manual. Can't seem to find what I'm looking for in either.
One of my problems is I'm just so damn burned out...I wanna ride already. My mind is fried to the point I'm having difficulty with the simplest of tasks.
What plugs you using RM?
Have you mapped it? Better check the connectors. Did it sound like it was running correctly timing wise (not cross wired)?
Rudemouthsky
Quote from: koko64 on April 30, 2015, 06:09:23 PM
Yes...but it really didn't run long enough to be sure. I remember the last time I crossed the wires on the Ignitech and it wasn't immediately obvious. I only had the bike "running" for a second maybe less...my "2 seconds" was def generous.
Could be. Not hard to  cross them. Have the paint pen ready to match the connectors if you try the other way and it runs correctly. You got a remote tank like a Motion Pro "drip bottle"? Worth having.
Remember, Ignitechs don't like non R plugs.
Tiz is the local Ignitech guy ay?
Rudemouthsky
For practical purposes the Ignitech is no different than the stock ignitors. I'm using R plugs for sure. Lets pretend I'm running stock ignitors for now?
Quote from: Rudemouthsky on April 30, 2015, 06:27:52 PM
Stock ignitors are very sensitive to grounding.
If they work...and then stop...it's never good.
I think the Ignitech are more robust.
Cross wired? Need more fuel? Nothing at the plugs when out and grounded?
I'll be back in a couple of hours and will check in.
Rudemouthsky
Quote from: ducpainter on April 30, 2015, 06:29:47 PM
So...if I cranked the bike without the system properly grounded...I could kill the ignitors?  :o
Quote from: Rudemouthsky on April 30, 2015, 06:35:35 PM
Maybe...
I have a story.
Many ignitors were harmed.
Rudemouthsky
This is what I've done as far as grounding the system...
Fat 4ga wire from negative battery post to the hollow bolt into the engine. I even went so far as to scrape away the powder coat on top even tho the bolt sinks deep into the case. The ground strap off the loom is hooked to the negative post. Sufficient?
I guess I'd ask how the Ignitek is grounded.
On the older carby bikes there was a ground strap between the frame and the cases, plus the battery grounds and any other grounds that Ducati thought were necessary.
Keep in mind I've already disavowed any specific Ignitek knowledge.
Quote from: ducpainter on April 30, 2015, 07:31:57 PM
I'd guess through the two mystery lugs and the loom ground, but that's a guess.
