January 01, 2025, 06:43:01 AM
Help Installing Rizoma Retro Mirrors
Topic: Help Installing Rizoma Retro Mirrors (Read 1887 times)
Crazy Canadian
July 14, 2008, 12:01:31 PM »
I just go them today. They come with an adapter (??) but not what I was expecting. I expected a bar end adapter that replaced the stock bar end and that the mirror clamped on to. The one that came with is just a larger diameter ring. Do I have to cut my grips apart to mount these? If so, that totally sucks. I know I will butcher that job. #$%*
2007 S2R 800, 14T Front Sprocket, Simple Tail Chop, SpeedyMoto Sliders, Arrow Steering Damper, Rizoma Reverse Retro Bar End Mirrors, Arrow Full Exhaust, Crazy Ass Driver.
Omnipotent Potentate
Personal Pretext
Re: Help Installing Rizoma Retro Mirrors
July 14, 2008, 12:29:00 PM »
They are intended to be mounted on the bar, or to proper bar ends like
these
these
- not to the little black plastic nubbin.
You can probably find some other cheaper bar end weights at any moto shop - I just know that those mirrors will fit the ones I linked to, and the method used to secure the end to the bar is nice and sturdy. IF you find others, avoid ones that just have a rubber plug that ones smooshes between the end and nut. That method works well enough for just the bar end, but won't deal well with the added stress of the mirror.
Don't cut you grips - you'll not be happy with the results.
S2R 800 '07
July 14, 2008, 12:37:57 PM »
Will they not fit on the stock bar ends? I know stock bar ends are much heavier than the Rizomas - supposed to reduce vibration, but I have no idea if that is actually happening.
Personal Pretext
July 14, 2008, 12:57:37 PM »
Quote from: stopintime on July 14, 2008, 12:37:57 PM
Which stock bard ends... Some monster don't come with anything more than a plastic nubbin in the end of the bar. IF he's to the actual weights, the mirrors should fit those.
teddy037.2
July 14, 2008, 01:18:53 PM »
+1 on going aftermarket bar ends....
if you happen to buy the rizoma ends, they'll fit right on. the other plastic rings are to fit on different OD ends.
Crazy Canadian
July 14, 2008, 01:59:05 PM »
Quote from: yuu on July 14, 2008, 12:29:00 PM
these
these
Don't worry. I won't cut the grips. I want them mounted under the bar and they will look crappy if not mounted right on the end!
Crazy Canadian
July 17, 2008, 10:33:09 PM »
They are at the post office and the whole works is going on tomorrow. Woo HOO!
ThelmaLou
August 03, 2008, 11:11:44 AM »
Quote from: Crazy Canadian on July 17, 2008, 10:33:09 PM
Pictures? How'd it go?
01 M6
00
Organ donation will save my fathers life!
Give Life! - Be an Organ Donor!
