TURN SIGNALS NO WORKIE!
Started by Rickrides, March 24, 2015, 09:14:38 PM
Rickrides
Out on a ride to the Rock Inn Sunday.  Tach stops working (already replaced once).  Then, at the next stop, I notice neutral light and turn signal indicator are not working.  Investigation revealed a blown 7.5A fuse.  Replace it.  Turned on the turn signals and it blew again.  Had a 10A and stuck that in and didn't activate the turn signals so I made it home with the tach and neutral light working.
The turn signals are aftermarket mini signals from Cycle Gear.  Were working fine before the fuse blew.
Four way flasher failure?
Thoughts are appreciated!!!!  Electrical issues are not my forte.
Rick
2000 Monster Dark 900 ie
Dirty Duc
Turn signal wire chafed a bare spot... shorting to the frame.
