« on: March 27, 2015, 02:24:23 AM » |
So I brought this home last night...
« Reply #1 on: March 27, 2015, 02:51:02 AM » |
So I went solo. -Me
Some people call 911..... some people are 911 -Marcus Luttrell
DesmoDiva
« Reply #2 on: March 27, 2015, 10:14:40 AM » |
'01 ST4 Yellow '02 ST4s Yellow
1.21GW
« Reply #3 on: March 27, 2015, 05:19:23 PM » |
This coming to DIMBY?
So many options...
« Reply #4 on: March 27, 2015, 05:37:34 PM » |
So many options...
Not enough suspension travel for NH
1.21GW
« Reply #5 on: March 27, 2015, 06:54:42 PM » |
Yeah, especially if Herm is planning another dual-sport route on Saturday.
« Reply #6 on: March 27, 2015, 07:04:58 PM » |
Enjoy!
ab
« Reply #7 on: March 27, 2015, 07:55:27 PM » |
sweet
620M 2004 Dark i.e.; ~ 57K miles (all me); Looking to swap out engine now. Triumph Speed Triple 2006 (now ~ 44K miles bought @ 4K miles on 04/2010) Honda Grom 2015 ~ 3500miles so far. Love this lil bike
« Reply #8 on: March 28, 2015, 03:01:54 PM » |
What year? Want my list of you should do this and why mods ?
-Throttle's on the right, so are the brakes. Good luck. - '00 M900S with all the farkles - '08 KTM 690 StupidMoto - '07 Triumph 675 Track bike.
« Reply #9 on: March 28, 2015, 04:02:24 PM » |
It's a 2012 with 3304 miles, all stock but has had the R/R recall done. Post that list asap! Just don't tell my wife
« Reply #10 on: March 28, 2015, 04:19:25 PM » |
2012.. Ok. Some info may be a bit date specific since they did updates along the way... But
If run hard, the heat exchanger unit likes to shit the bed. It's the odd round gizmo on the front of the case with coolant hoses running to it. If it gives up, it blows coolant into the oil. There's a couple flavor of kits out there to separate the oil cooling from the water totally
Rear suspension linkage is progressive fwiw. I found it to be a tad problematic since the springs were soft for me and I'd get a lot of squat getting on the power coming out of corners
The automatic cam chain tensioner isn't so hot. There's manual replacements
The gear shifter shaft is kinda long and can be sloppy. There's an external support for it from Sato.
If your looking for rearsets, look at Attack. Well done, swaps from regular to GP shift with one bolt. Lots of adjustments and features to protect them in a crash.
You can use TuneECU on it for free. Plenty of mapping info out there. Also can let you adjust the speedo to correct for gearing changes. You do need a windows computer or VM and an ODB cable.
Captive wheel spacers and a captive rear caliper mount make wheel changes a lot easier
« Reply #11 on: March 28, 2015, 05:05:50 PM » |
Very interesting.
Define "run hard". I was unaware of this heat exchanger.
My 06 had no problems with any of these things and it was definitely run hard at the track. 13000 trouble free miles with that one.
« Reply #12 on: March 28, 2015, 05:18:03 PM » |
Tracky, trackish - check out the 675 forum.
Oh and if you get up to creating anything custom Lmk. I've got an 07 track bike. So many components are shared from 07 until the 2013 redesign.
« Reply #13 on: March 28, 2015, 05:28:33 PM » |
Custom as in machined stuff?
« Reply #14 on: March 28, 2015, 06:39:03 PM » |
Congrats.
