anyone had problems with their gauges acting up? just repaired mine BUT....
Started by djomlas, March 31, 2015, 09:17:48 PM
djomlas
i was having issues with my 07 s2r cluster as it had a bad speedo, wasn't telling me how fast i was going and some LEDs inside were bad.
sent it off to SOS diagnostics and now when i turn the bike on almost all the lights are on, neutral light works as it should, BUT turn signal light is constantly on (weather or not you use turn signals, turn signals themselves work ok, but light is always on), low fuel light always on, full gas tank, and high beam light always on, weather or not its on doesn't matter, its always on.
anyone know what the heck is going on? is this common? couldn't it be happening because i had the cluster out?
is there maybe a simple trick? like disconnecting battery or something like that?
thanks in advance guys
S2R
Rizoma rearsets, full Zard CF dual exhaust, Rizoma clipons, Sargent seat, 999 shock, golden brembo calipers/rotors upgrade,adjustable levers and billet grips, some CF (belt covers, heel guards, chain guard sprocket cover, fender, bellypan), integrated R6 tail light, bar end mirrors
other bikes in garage: 08 hayabusa, 06 hayabusa, 07 zx14, 07 r6, k6 gsxr1000, r1, 08 zx6r, triumph speed triple,2 vespas and a ruckus, its an obsession
You can try disconnecting the cable, but I have my doubt this will help.  Have you called SOS?
djomlas
yes, they said email us and tech will email you back, so well see...
S2R
