January 30, 2025, 10:52:45 AM *
Author Topic: Machining the handlebar mounts after clip ons  (Read 3258 times)
darksouls
« on: April 02, 2015, 01:44:13 PM »
I'm a machinist by trade and just got the woodcraft 2" rise clipons. I'm considering machining the stock mounts off and polishing the whole clamp. Has anyone done this? Lot cheaper than buying an aftermarket one i suppose.
S2R 800 '07
« Reply #1 on: April 02, 2015, 02:08:46 PM »
That has been done and it looks great  Cool
There will be holes in the triple where the raised mounts are/were.
oldndumb
« Reply #2 on: April 03, 2015, 04:58:21 AM »
Is it still a hole if it is filled in?  Wink
Two aesthetically acceptable options come to mind. The first being to take it to a proficient TIG welder and have the holes filled and then you machine them. The welder would probably appreciate a backer plug in the holes before he starts. The other option is to turn a couple interference freeze plugs. Clean up and measure the holes, then turn the plugs .003" o'size. Freeze them with dry ice and acetone and then decisively install them. Then machine them. Several final finish options are possible. 7075 T6 Al would be great, but even 6061 should work.
S2R 800 '07
« Reply #3 on: April 03, 2015, 08:04:01 AM »
I think the holes look fine - maybe even better than not. I did a search, but didn't find pictures - they are here though.
oldndumb
« Reply #4 on: April 03, 2015, 08:07:24 AM »
I've seen them with SS button head screws in them, and they looked fine also.
S2R 800 '07
« Reply #5 on: April 03, 2015, 08:11:32 AM »
I'm talking about removing the whole bar mounts, leaving holes the size and shape of the mounts  Wink
Enjoying the ride
« Reply #6 on: April 03, 2015, 08:35:33 AM »
If it is a 620/800 Dark the mounts are part of the top triple, no hole visible . . .
Have a look at my bike, 620 Dark
https://www.flickr.com/gp/darkmonster620/T6J27h
oldndumb
« Reply #7 on: April 03, 2015, 08:40:42 AM »
Sort of like the 999 top clamp?
S2R 800 '07
« Reply #8 on: April 03, 2015, 09:09:51 AM »
Closest I could find.
http://www.ducatimonsterforum.org/index.php?topic=31671.msg553966#msg553966
darksouls
« Reply #9 on: April 03, 2015, 12:02:59 PM »
not a bad idea machining slots connecting the holes.  waytogo Had the bike 1 week and i already got it torn apart. I'm considering doing the tail chop also but i need to read more on it.
xcaptainxbloodx
« Reply #10 on: April 03, 2015, 02:45:34 PM »
orrrrr get an upper and lower set up from a sport1000
darksouls
« Reply #11 on: April 07, 2015, 01:01:31 PM »
well i got the clip on's on and tree machined, not my "casket" style brake and clutch reservoirs interfere with the woodcraft 2 piece clip ons. I got new cheapo adjustable levers coming from moto777 and im wondering if they with pair with the spacers for the brake/clutch levers or is it a better idea to just go with cup style reservoirs?  bang head
Another option is ebay knockoff sets for like $80 bucks, not sure if i trust those though.
« Last Edit: April 07, 2015, 01:06:45 PM by darksouls » Logged
S2R 800 '07
« Reply #12 on: April 07, 2015, 01:53:20 PM »
If the levers adjust enough to compensate for the spacers, you're all set  waytogo
Rudemouthsky
Autonomous red and black
No gods and no masters
« Reply #13 on: April 11, 2015, 05:30:57 AM »
pics
