Oil on valves
Started by lazylightnin717, April 07, 2015, 06:41:45 PM
lazylightnin717
I'm in the process of tearing down the 02 S4 for the 24k service. 'Twas planning on valves, belts, and any flaking rockers to be taken care of.
I noticed with the TBs pulled to the side that it looked like there was oil on top of the valves. I will take a closer look tomorrow to confirm but in the meantime, I'd like some thoughts on why it may be occurring and how to fix it.
Comes a time
Says don't you see
Gotta' make it somehow
EEL
Where is your breather connected?
lazylightnin717
Quote from: EEL on April 07, 2015, 09:37:17 PM
Stock configuration.
Quote from: ducpainter on April 08, 2015, 03:04:38 AM
Valve seals
Pretty obvious answer. Have you swapped them out on a desmoquattro?
Comes a time
Says don't you see
No, but I'd weigh all the circumstances before I jumped to any conclusions about them 'needing' to be replaced.
Did the bike have oil consumption issues last season?
How long did the bike sit to accumulate how much oil on the valves?
Are the seals the type that lock on to the guide, or are they the type that float on the valve stem?
Some oil on the valve stems is not necessarily a bad thing.
Quote from: ducpainter on April 08, 2015, 04:26:53 AM
Some oil on the valve stems is not necessarily a bad thing. DING DING!
Also, are we looking at wet unburnt oil or black residue?  Intake or both?
lazylightnin717
Not sure about the type of seal. They looked locked into place with a small coill around the top.
The bike has been sitting for the winter. About 6 months.
It was last ridden hard for a few hundred miles in the mountains down in WV. I did notice really low oil level when I returned from the trip. I just attributed it to hard riding. The guys riding behind me confirmed no smoke.
I don't have the exhaust off to check those valves. The intake valves have both burnt and wet residue.
Comes a time
Says don't you see
This is just me...
if the bike doesn't smoke, and isn't using more than a quart of oil in about 1k miles.
I'd leave it alone. It's a machine, and they use oil. Replacing valve seals might help, but if the guides are worn it's a temporary fix.
If you're the anal kind and absolutely have to find the reason the bike used a quart of oil after a season of riding...
get out the checkbook. It won't be cheap.
lazylightnin717
Trying to keep the checkbook in my pocket  ;D
Comes a time
Says don't you see
EEL
I'd say your breather valve is pushing oil vapors into your intake valves.
I believe the breather feeds into the air box on that monster, so he'd also see oil pooling there or dripping out of the air box drain.
jduke
If the breather is pumping oil mist into the air box and then into the engine, you have an issue that needs to be fixed.
Could be rings, guides, valve stem seals.
If the breather is dry, and the valve stem seal doesn't appear to be torn or split, then it's probably the valve guide. You can use a dial indicator to check for play if you can't feel the looseness.
Almost any automotive cylinder head shop can replace the valve guides pretty inexpensively. If you can find an old VW mechanic he can easily handle it.
Get out your checkbook. The guys are spending your money. ;D
EEL
Quote from: ducpainter on April 08, 2015, 01:57:41 PM
Thats a very good point. I didn't think about that..
So that begs the question. Is there oil in the airbox??
Assuming the bike was running fine before,  no blue smoke, no plug fouling, no loss of power and no excessive oil consumption you might be trying to fix something that ain't broke.  If valve guide cleared and seals are OK and there is no excessive oil in the air box I say butt [n it up and see what you got.
