how do you clean an exposed clutch?
Started by hydra, July 14, 2008, 06:10:20 PM
hydra
i've had a cover on my clutch since i've had my bike (2.5 mos). but i'm about to swap it out with a speedymoto open clutch cover. i've got a yoyodyne slipper clutch...
i guess i should avoid getting water in there when i'm washing the bike or at least as much as possible? how do you clean it up in there. i opened it up for the first time to have a peak and it looks like it could use a cleaning. it's not filthy, just a bit dirty.
thanks
S4 Foggy- tires, battery...
BE WATER
Quote from: hydra on July 14, 2008, 06:10:20 PM
thanks
I blast it with compresssed air, then shoot it full of water, then run the bike till it dries. I do this once a month
truckinduc
the normal clutches like to stick after they get wet. You crank it and put it in gear and it lurches forward and stalls. I wash mine like i wash the rest of the bike. Then crank it while wet to quickly dry the clutch.
ghostface
Quote from: He Man on July 14, 2008, 08:27:47 PM
Beware of Asbestos.
knightrider
i dont believe they use asbestos anymore.  i think its outright illegal no?
1994 M900
55Spy
Just wash it and then run it for a bit to dry things up (run to the store and grab a sixer) and then put it away.
Quote from: ghostface on July 15, 2008, 09:32:59 PM
Beware of Asbestos.
Asbestos is illegal in all of the US, not sure on europe. However i will ask anyway, why would there be asbestos in there? The dust is just iron from the plates rubbing against each other.
edit: nvm, i forgot what Asbestos was when i posted that. I was not aware that there could be asbestos but i highly doubt it. That stuff is illegal in most countries
knightrider
asbestos used to be used in the friction material in brake pads and clutch disks. i would think the only place to find it would be an old car thats been hiding in a barn.
1994 M900
There is no asbestos, but use caution anyway.  No reason to believe the new materials are safer and all foreign material is bad for your lungs.
silas
I don't know about motorcycle clutch parts, but I would not be surprised if a small ammt is still in there.
I'm an architect and many building products such as mastics and adhesives still contain a trace ammt of asbestos to this day.
The laws limit the percentage.
Ride fast, ride safe
'98 M900, '92 Yamaha TDM850
ODrides
Probably safe to not inhale any dust you blow off your bike.  Just in general.  ;)
