January 06, 2025, 06:34:09 AM
Removing T-Rex Frame Sliders
Topic: Removing T-Rex Frame Sliders (Read 1789 times)
The ModFather
Duck Off
Monster Magnet
April 24, 2015, 12:40:51 PM »
I put some T-Rex Frame Sliders on my Monster 620 and i remember it being pretty easy. I now want to take them off but want to make sure I'm doing it properly. Anyone have the install guide? I've been searching this and other forums but cant find anything.
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
Re:
April 25, 2015, 10:17:17 AM »
Do u have the stock engine bolt?
The ModFather
Duck Off
Monster Magnet
Re: Removing T-Rex Frame Sliders
April 25, 2015, 12:40:23 PM »
I do.
2008 848 Track Bike
Re:
April 28, 2015, 03:42:06 PM »
Use the stock bolt to push out the t rex bolt
Two dogs
April 28, 2015, 10:53:03 PM »
And support the engine from under neath before you start tapping it through.
The ModFather
Duck Off
Monster Magnet
May 10, 2015, 09:02:18 AM »
Im pretty sure when I put the T-Rex Frame sliders in I had the rear of the bike suspended from above with ratchet straps hooked to the passenger grab rails on the frame then I set a cinder block underneath & set it down just enough for the weight of the engine to be supported by the cinder block. is that overkill? Will paddock stands front & back & a jack for the engine be sufficient?
2008 848 Track Bike
Enjoying the ride
May 10, 2015, 01:53:07 PM »
Rear stand, jack under engine with a piece of wood to lift/lower the millimiters . . .
Don't forget to grease the bolt, nuts and threads . . . also the contact patch with frame
The ModFather
Duck Off
Monster Magnet
May 10, 2015, 03:25:39 PM »
Pardon ny ignorance. What do you mean by "lift & lower millmiters" & "contact patch with frame" ??
2008 848 Track Bike
Enjoying the ride
May 10, 2015, 03:42:12 PM »
Quote from: The ModFather on May 10, 2015, 03:25:39 PM
with the jack you will lift the engine just enough for frame bolt to come out/in . . .
the part or the nut/washer that makes contact with the frame . . .
The ModFather
Duck Off
Monster Magnet
May 10, 2015, 07:36:50 PM »
Thanks so much for all your assistance.
2008 848 Track Bike
Enjoying the ride
May 11, 2015, 04:41:32 AM »
Hey, if I can help I will help . . .
