1100ds belt tension
Started by SpikeC, April 30, 2015, 06:23:54 PM
Quote from: oldndumb on May 01, 2015, 11:19:43 AM
Yep, a Friggin Magic Twanger, better known as an FMT to be precise.  ;) The dealers use a similar, if not the same, set up.
Which is why I have always been suspicious of audio tuners, but admire the fact that our belts persevere.....most of the time.  :)
AFAIK the dealers have an optical tool, but whack it by hand.
Needless to say two different tech will get different results.
memper
So then why not switch back to the ol' allen key method? Seems the fancy dohickey is hard to get repeatable results, no?
I use the OEM and the MotoReva units . . . Usually within 7Hz at the same point of measurment... and use the 5mm allen to "check"
SpikeC
 OK, I went for a little ride today and did an oil change. While I was at it I pulled the belt covers and there was less than a mm of clearance twixt the roller and belt, so I increased it to 4mm. After I get the oil back in I shall see how she sounds, but I dint think that I will be bothering with the "pluck your magic twanger, foggy"!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
oldndumb
SpikeC
Hahahaha!
Butt serially, after I buttoned up the oil change and started it up it sounds just as happy as can be!
Spike Cornelius
  PDX
   1965 T100SC
If now all models are set the same, then the 5mm/6mm allen key method can be used on the 1100/1000 models? Correct? Or is it 5/6mm for 900/750s and 4/5mm on 1000/1100s? I know someone who does the litre+ bikes with 4/5mm.
In the end, if theyre not loose enough to slip and not tight enough to strain the bearings then youre ok. I mean how many bikes are running with perfectly tensioned belts.
oldndumb
Quote from: koko64 on May 02, 2015, 01:50:31 PM
My thoughts exactly.  :)
SpikeC
Mine is! Because I said so!
Spike Cornelius
  PDX
   1965 T100SC
Everyone that has them adjusted so they don't jump or make the bearings noisy. ;D
Considering the bearing collapse issues caused by the over tight incorrect oem spec, it's been the "common sense" spec all along. ;)
Armor
The 5 mm allen key is way too loose for the 1000/1100 motors.  Your bike will run better with the tighter belt.  The sonic method works if you have the correct tool.
SpikeC
 I have them set to a very snug 4mm. The engine sounds just dandy!
When I took the original belts off in November of '13 a 5mm just barely fit, and I had no idea how long they had been in there, the motor is an '07 and it had 6k miles on it.
Spike Cornelius
  PDX
   1965 T100SC
I knew I had taken a screen shot of the Ducati Web educational video regarding belts . . .the date is April 2014
vertical cyl 2v
hor cyl 2v
