1100ds belt tension
Started by SpikeC, April 30, 2015, 06:23:54 PM
SpikeC
 The engine is from a Multistrada 1100DS, and it lives in my Bimota. In September of 2013 I installed a set of Exactfit belts that Cal Cycleworks supplies. When I did the instal I checked the tension they had and used the same for the new ones. A few days ago I rented a harmonic do-hicky from Ducati tool rental. The device was rather difficult to get reading with, but I was able to get a reading of 110 hz give or take a couple. They felt quite tight compared to what I had set them at.
Then I looked up the specs in the factory shop manual and they spec the 1100s motor at 140hz. The book says to tighten used belts to 140 if they are down to 70, so there seems to be a pretty broad range.
Now my bike has an aluminum fuel tank, so engine noise is transmitted pretty well to the rider. after tensioning the belts to 110 there is quite a bit more engine noise coming up.
I am wondering what the experience has been for others with this motor. This one has a wet clutch so there is less background noise to mask other engine noises!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
oldndumb
I could not get that particular tool to work with any degree of consistency, especially on the vertical cylinder. I used the Gates belt app on my Android. I have better luck with that than the guitar tuners.
https://play.google.com/store/apps/details?id=com.gates.carbondrivecalculator
jduke
The manual is probably wrong, I would go with California Cycleworks 110 hz.
Check them about in about 600 miles.
memper
Is it wise to adjust belt tension after they are warm or cold?
oldndumb
Quote from: jduke on May 01, 2015, 06:04:22 AM
Wot he said. ^
Quote from: memper on May 01, 2015, 06:07:34 AM
Belt tension is set cold.
Quote from: oldndumb on May 01, 2015, 06:10:31 AM
Wot he said. ^
Ditto...if you set them at 140 you'll destroy tensioner or idler bearings.
SpikeC
Well, I set them cold, at 110hz, according to the Ducatitool tool, and double checked with the Gates, and it showed 60hz which I know wasn't right as the belts seem quite tight.
The factory does specify 140 for this engine only.
The thing that concerns me is the increase in mechanical noise that I'm hearing.
Spike Cornelius
  PDX
   1965 T100SC
Quote from: SpikeC on May 01, 2015, 07:21:52 AM
The factory changed the spec. 140 is wrong.
It's the bearings complaining. Check the bearings.
You should check the belts hot just to see how tight they really get. It's amazing how much the tension increases. You might be able to back off on the tension when cold to quiet things down.
Since your belts are now "used", set them between 100Hz~110Hz +-5Hz . . .This is from my OEM manual, updated Jan15 . . .for 2V engines, no matter displacement.
I had a screen shot of it, but, it was on the damaged laptop, sorry bout not having a pic
SpikeC
 Thanks for all the feedback, guys! Since the book says to tighten them up when they get down to 70hz a little loose does not seem to be a problem! Too bad that the unit that desmotool rents does not register that low. I think I had to get the belts up to nearly 100 to get it to register at all.
Spike Cornelius
  PDX
   1965 T100SC
Quote from: DarkMonster620 on May 01, 2015, 07:56:07 AM
They must want to sell tensioner bearings if they're using the same spec on all 2V motors.
oldndumb
#11
Quote from: SpikeC on May 01, 2015, 09:21:26 AM
No indication that this is the case in your instance, but getting a reading can be a function of the "twang" technique. In my case, I can go through a series of no/low readings to the point of frustration, only to then find the correct technique and get repeatable readings without knowing what I had done differently.
I can't help but feel that measuring the roller gap is better than checking the frequency, unless you are using the factory tool.
Quote from: ducpainter on May 01, 2015, 09:28:00 AM
according to them these new values DIMINISH the wear on said components . . .
Quote from: DarkMonster620 on May 01, 2015, 10:28:29 AM
You know how they lie. [bang] [bang] [bang] [laugh]
According to them the belts on my old 900 should be the same frequency?
Quote from: oldndumb on May 01, 2015, 09:56:41 AM
The tool they use on the assembly line is optical and has a built in twanger
oldndumb
Quote from: ducpainter on May 01, 2015, 10:37:17 AM
Yep, a Friggin Magic Twanger, better known as an FMT to be precise.  ;) The dealers use a similar, if not the same, set up.
Which is why I have always been suspicious of audio tuners, but admire the fact that our belts persevere.....most of the time.  :)
