S2R 800 exhaust compatibility between years?
Started by flanman, May 06, 2015, 06:28:52 PM
flanman
I have an 07 S2R 800 and am going to be finally getting rid of the stock setup. I noticed on motowheels the Spark midpipe has its own model/sku for the 2007 year and another model/sku for 2004-2006.. Does anyone know if there are fitment issues between the years? Thanks ahead of time   [thumbsup]
MV
Not 100%, but I suspect the later model version just has a bung for the O2 sensor... Might be worth checking with the vendor.
Quote from: MV on May 06, 2015, 09:10:15 PM
Correct.
My '07 Spark came with a hole for the sensor, but I already had the DP slip ons, filter, open air box lid and ECU so I had to plug it.
If your bike uses/needs the sensor it's plug and play.
flanman
Thanks! I figured it was a sensor thing, just wanted to double check.  [Dolph]
Rizoto
With the DP ECU, you don't need the sensor.
Monster S2R 1000 - Superbike 748
