no power!?
Started by samuraibiker, June 02, 2015, 06:07:49 AM
samuraibiker
hey guys
havent ridden my 97 monster 400 for a while... key in the ignition yesterday, started fine, idled nicely, revved fine...went for a ride.... wtf???? had someone stolen the motor and put in a honda cub one???? absolutely no power, no acceleration... limped home...both cylinders hot and firing, plugs good, battery fine.... any ideas? could it be a fuel starvation issue? fuel filter? fuel pump? any help much appreciated!
monster 400 evolving into a 900; vespa px150, vespa gs 150, suzuki grasstracker 250 60s custom tracker, honda cbr1000rr
Could be lots of things.
What did you last do to the bike?
samuraibiker
hey duc
last thing i did was change the ignition pick up coils , new plugs ( ngk ), new battery, oil change.....
You rode it after the pick-ups and it was OK?
samuraibiker
was fine and dandy...then didnt ride for about a month ( or more )
samuraibiker
have been searching around like mad for a day now...  fuel related issue? the filter was changed less than 2000 kms ago .... the fuel pump and all other fuel hoses etc are the originals from 1997...
I'd check to see if the tank vent line got kinked the last time you lifted the tank.
samuraibiker
hey duc
thanks... i think i will check all those lines/ hoses etc... worth pulling off the fuel pump and cleaning it out?
Quote from: samuraibiker on June 02, 2015, 07:16:16 AM
hey duc
If the filter is working there shouldn't be anything in there.
I'd do one thing at a time.
samuraibiker
ok.... check all hoses...no clogs, splits etc...
changed fuel filter
same problem... i noticed that from idling, when revs are increased slightly, the engine doesnt run smooth... timing issue?
when i changed the ignition pick up coils i didnt / couldnt set the gap between the coils and the alternator as they are fixed hole type... but could it be the ignition coils causing bad timing??
Could be timing or pick up gap.  Timing can be checked with an old fashioned timing light without taking anything apart.  Coils will not affect timing unless you have them mixed up.  since the bike idles well that should be correct.  Timing and gap are adjusted by loosening the pick ups and moving them on the bracket.
There is a spec on the pick-up air gap. It should be .6mm. There was just a thread about bad gap/timing.
http://www.ducatimonsterforum.org/index.php?topic=70988.msg1311402#msg1311402
Where did you get the replacement pickups?
samuraibiker
hey howie/ ducp
firstly..big thanks for your comments... taking the time to help me out is really appreciated
the gap between the flywheel and the coils wasnt adjustable because my coils are the holes only ones.. no movement possible... and the position of the coils on the bracket also wasnt adjustable due to the simple single holes
bought them on ebay
http://www.ebay.com/itm/1-pickup-zundgeber-ducati-600-750-S-900-ss-monster-2v-ignition-coils-pick-up-new-/160690718980
i didnt move the bracket at all, just replaced the coils thmselves
this is definitely a timing/ pick up coil issue........
The gap can still be adjusted slightly by using the clearance between the bolts and the holes both on the pick-ups and the timing plate.
That doesn't seem to be your problem though as you said the bike was fine after you changed them. The gap shouldn't suddenly be an issue unless your plugs are fouling due to a weak or mis-timed spark.
Check the plugs?
samuraibiker
hey ducp
the plugs were black as hell actually...had to give them a good clean.... and they are new plugs!
so...mis-timing spark?
