Ohm3d
« on: June 02, 2015, 08:49:34 AM » |
« Reply #1 on: June 02, 2015, 08:52:17 AM » |
Soooo much nicer.
JohnEE
« Reply #2 on: June 02, 2015, 09:00:27 AM » |
Such a great color combo. The comp works cans are unique too, nice bike!
Ohm3d
« Reply #3 on: June 02, 2015, 09:17:17 AM » |
gotta wrap the pipes still and need to do something with the clutch housing. I saw some nice clear cover conversions... a la Ducabike. otherwise, its pretty much as far as I can go without doing big valve heads and pistal pistons.
Rudemouthsky
Autonomous red and black
No gods and no masters
« Reply #4 on: June 03, 2015, 03:49:59 AM » |
Oh damn that matte (grey..silver..titanium..what's it called?) Looks great!
SpikeC
« Reply #5 on: June 03, 2015, 10:48:16 AM » |
It is looking very nice! However, in my mind pipe wrap would not enhance it, rather I would get them ceramic coated to match the finish on the rest of the bike.
Spike Cornelius PDX 2009 M1100S Assorted blingy odds and ends(now gone) 2008 Bimota DB5R woo-Hoo! 1965 T100SC
oldndumb
« Reply #6 on: June 03, 2015, 10:57:51 AM » |
I had pipe wrap on for about a month or so and then needed to remove a section of it and was surprised to see the pipe condition. It was severely discolored and had surface pitting which matched the wrap weave. Luckily I was able to save the pipes with a whole lot of sanding and polishing. I now have polished pipes which are easy peasy to take care of.
Moral of story, if you do a pipe wrap, you can expect the pipes to look like crap if you ever remove the wrap.
Blackout
« Reply #7 on: June 03, 2015, 11:58:07 AM » |
Pipes look great.
2003 Ducati Monster 800 2005 Triumph Speed Triple 1050 2003 Honda CR250 2008 KTM 990 SuperDuke
xsephirot
« Reply #8 on: June 08, 2015, 12:24:26 PM » |
Love the pipes. Do you have a link where I can get it?
Ohm3d
« Reply #9 on: June 10, 2015, 11:09:30 AM » |
The reason I want to wrap the pipes is that is melts the heel of my boot. Tried a few options of putting a heat shield on and they all looked like cap.
The colour is a custom blend done by a local paint guy. Started off with Senna grey and added a lil magic. His work is top notch to say the least. That tank was originally a Tricolore tank, because I wanted to run the newer style of fuel pump.
Exhaust is arrow header, custom mid-pipe, and custom cans. It was a Bellisimoto custom exhaust that didn't fit (turns out the measurements for S4Rs and S2R800 are Waaaaaaaay different) and required significant cutting and welding to work.
Devo68
« Reply #10 on: June 10, 2015, 11:00:33 PM » |
nice bike!
xsephirot
« Reply #11 on: June 11, 2015, 10:19:26 AM » |
What did you do with the tuning? ECU flash or a piggyback?
2WheelsFTW
May the torque be with you
« Reply #12 on: June 11, 2015, 10:42:58 AM » |
That color combo is killer, reminds me of an S4R
Drink Beer. Ride Motorcycles.
Ohm3d
« Reply #13 on: June 11, 2015, 08:52:39 PM » |
its got a DP ecu flash, and PC3, dyno tuned
Ohm3d
« Reply #14 on: June 12, 2015, 06:41:48 AM » |
That color combo is killer, reminds me of an S4R its actually very close. I priced it out and it probably would have been cheaper to just but an 07 S4R gret tank and tail. the exception is that the S4R has a black stripe on the tank and tail and that wasn't the look I was going for.
