Valve clearances for 09 696
Started by fragile_this_side_up, July 02, 2015, 05:53:58 AM
Confused!! Looking at the manual it says the opening shim should be .05-.15 and closing .00-.20? What???
The .00-.20.. I feel like .00 is a little, i dunno, tight? .10-.15 is understandable for the opening gap.
Well first of all those dimensions are in mm.
The 2V Ducs run best with the closer set as close to zero as possible without causing drag on the cam when rotated by hand.
If you remove the belts you can feel the drag if you get it too tight.
OK. thanks for the clarification. yes, i know in MM. SO LITTLE PLAY!! first timer here, so i'm just making sure i don't mess it up.. thanks so much for the clarification.
