January 06, 2025, 03:14:54 AM
796 front suspension
Topic: 796 front suspension (Read 1585 times)
Dochunt
July 06, 2015, 06:48:23 PM »
The front end seems to dive on hard braking with my 220 lbs shifting forward despite tank grip pads.
What is a good way to stiffen up the non-adjustable front suspension?
Would changing just the spring or the oil be enough or do I need both?
I am trying to find a good shock mechanic in South/Central Jersey.
Would lowering the rear help?
Thanks in advance again.
Aprilia Caponord 1200 2015
M796 ABS 2012
Triumph thunderbird Sport 1998
SpikeC
Spike in PDX
Re: 796 front suspension
July 07, 2015, 03:16:12 PM »
I would leave the rear alone, the easy thing to do would be to put a spacer wonder the fork cap to increase the preload of the spring. If that helps look into a new spring with a high rating. Looking at then oil volume in the forks would be a good idea, as well as a heaver weight oil.
A trip to a suspension tech would be a very good idea!
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
GreasySnipe
July 07, 2015, 05:28:49 PM »
I agree on seeing a good suspension tech if you are not capable of the job. Depending on where your Preload is at with the non adjustable forks( with the weight of you wearing your normal gear), a respring and revalve could be in the works to get that front dive under braking under control.
Dochunt
July 07, 2015, 06:17:11 PM »
Great. Thanks.
Now to find the right tech.
M796 ABS 2012
TWDucfan
Will the Ohlins front suspension from M1100S
July 07, 2015, 10:33:55 PM »
fit the 796 ?
Will it be a straight swap or require modifications ?
How much improvement can be expected ?
Dochunt
July 08, 2015, 12:35:13 PM »
I found I suspension tech nearby that is also a Ohlin dealer.
I will go see him in the next few days
M796 ABS 2012
TWDucfan
July 10, 2015, 06:09:28 AM »
Quote from: Dochunt on July 08, 2015, 12:35:13 PM
Will be interested to know, please keep us updated.
