January 06, 2025, 03:19:03 AM *
Pages: [1] 2   Go Down
Author Topic: Did I just flushed some $500 away?  (Read 5017 times)
CookieMonster
me like twisties NOM NOM NOM!
Mone Rone
« on: August 05, 2015, 10:24:41 AM »
Ok so when I purchased my bike, I got her without a code card nor a red key. I was a bit worried that I was taken. I searched high and low and found out that I could get it retrieved and pretty much get back what was missing as if it never was. Some had said that I had to get a whole new package that included new ignition keys, red key, code card, ECU, cluster and locks all for a pretty penny worth over $3k, then I also found the cheaper alternative that was retrieving it all for $500 that included code card and red key and a spare black one. So I was happier than a pig in a blanket.
So now I am going bonkers, upgrading levers (waiting for them to arrive), said bye bye to the udder (waiting for that to arrive as well), brought the bike back to original spec (previous owner lowered it), adjusted chain and a High Flow K&N air filter. So I starting to search for an exhaust and ended up picking Mivv (that will be the next big ticket item to go on the bike). But then I started reading how I would have to reflash my ECU. Finding out that the reflash would get rid of the immobilizer thus pissing away some $500 I could've used somewhere else on the bike. Does that sound accurate?
« Last Edit: August 05, 2015, 11:57:18 AM by CookieMonster » Logged
"Friend don't let friends ride stock"
-S2R1k 992 DESMO LIFE
TitanMonsterS4R
« Reply #1 on: August 05, 2015, 10:32:24 AM »
Ok so when I purchased my bike, I got her without a code card nor a red key. I was a bit worried that I was taken. I searched high and low and found out that I could get it retrieved and pretty much get back what was missing as if it never was. Some had said that I had to get a whole new package that included new ignition keys, red key, code card, ECU, cluster and locks all for a pretty penny work over $3k, then I also found the cheaper alternative that was retrieving it all for $500 that included code card and red key and a spare black one. So I was happier than a pig in a blanket.
I really dont want to say you wadded $500.00 away but you may have with your mods, etc.
CookieMonster
Mone Rone
« Reply #2 on: August 05, 2015, 10:44:53 AM »
Great, so pretty much that's what I did and you're just trying to be nice. So I would've been just fine with a duplicate key and just reflash from the get go?
TitanMonsterS4R
« Reply #3 on: August 05, 2015, 10:50:45 AM »
With a different air mod and what I think is a full system (minus the udder) the bike will need to have the air/gas ratio fiddled with. It could be as simple as that. However, if a you need a reflash, then yes you wadded $500 dollars. A reflash is somewhere in the neighborhood of 3-4 with keys.
Sorry bro, we'll all learned an expensive lesson owning these bikes. Trust me I have my pair share (ie leaving a rotor disk on when trying to ride the bike = bent aftermarket rotor = no riding until new one arrives, etc. etc. etc.)
xcaptainxbloodx
« Reply #4 on: August 05, 2015, 10:56:51 AM »
a reflash can remove the immobilizer if you want it to. By all means if you like the security it provides and you just spent the cash to keep it active do not feel that it has to be removed.
So I wouldn't say it was wasted, just an unnecessary perk.
Dochunt
« Reply #5 on: August 05, 2015, 04:04:24 PM »
Pardon my ignorance about these bikes but when I bought my M796 a few months ago, it just came with one key and an owners manual.
Did I miss something?
Aprilia Caponord 1200 2015
M796 ABS 2012
Triumph thunderbird Sport 1998
« Reply #6 on: August 05, 2015, 05:06:33 PM »
No, fuel-injected models previous to the M696/796/1100 came with the code card, red key and two black keys.
Dostie
« Reply #7 on: August 05, 2015, 05:38:00 PM »
What was it that you did that only cost $500??
And how would one go about re-flashing a bike w/o code card/red key?? Specifically 2007 S2R 1000.....
CookieMonster
Mone Rone
« Reply #8 on: August 05, 2015, 06:07:20 PM »
I got a code card, a red key and a spare made, when I purchased my bike it didn't have any of those and was able to talk the additional cash up. Some say that a Ducati without the card/red key is devalued when you look to sell it.
If you reflash then you won't need any of the latter and will be fine with just the black key you currently have because in a reflash you can chose to no longer have that option.
Dochunt
« Reply #9 on: August 05, 2015, 06:11:48 PM »
Great, thanks for the education.
M796 ABS 2012
xcaptainxbloodx
« Reply #10 on: August 06, 2015, 09:43:13 AM »
When you reflash a bike, you flash the ECU.
The immobilizer is a chip in the key that is registered by the dash.  The ECU only verifies with the dash and will not start the bike without that verification. When you flash a bike to remove the immobilizer, you stop the ECU from asking the gauge about the immobilizer.  They yellow blinking light will stay on at the gauge to indicate a failure with the immobilizer, but the ECU wont care about it.
This allows you to get mechanical keys cut so you can start and lock your bike, but dont have to hassle with lost red keys or code cards.
fragile_this_side_up
« Reply #11 on: August 06, 2015, 01:02:00 PM »
M696 has code cards too.. I don't have one. Mine will be reflashed soon.
I have Mivv's already. Love 'em.
The ModFather
Duck Off
Monster Magnet
« Reply #12 on: August 06, 2015, 02:39:28 PM »
You dont need the Red Key. Two Black Keys are all you really need. You can get a duplicate black key made and chipped to match your immobilizer for under $30 by a local locsmith. Back in the day the only way to get a duplicate key made was with the red key but now they have RF readers that will read the rf signal in your existing key and they can duplicate it in a new black key for you. With regards to not having a red key reducing the value I'd say that's negligible. SOS Diagnostics can get you around most any problem you may have with your key, ECU and Immobilizer.
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
CookieMonster
Mone Rone
« Reply #13 on: August 06, 2015, 03:00:08 PM »
And I sit here waiting for them to call me, collect payment and send my stuff back so I can ride dammit! bang head
Curmudgeon
« Reply #14 on: August 09, 2015, 09:33:20 AM »
Your 796 was delivered to the first owner with two keys and a code card. If your immobilzer locks up, you'll need a new instrument cluster with code card if you want to keep it stock. New keys are easy enough, but the code is needed to program them.
No clue about modding and reflashing on newer bikes. Perhaps an option as long as you're not keeping it stock.
Pages: [1] 2   Go Up
