1000 S2R Bearing Crankshaft death
Started by pepeducat, August 06, 2015, 01:20:23 PM
pepeducat
During the emptying of the engine of a friend, it was found metal particles on the drain plug .....
here nothing
by cons here .....
So I go out under the engine
successful extraction ;D
And engine teardown
And this is the culprit, the damaged ball right and left a ball in good condition ....
Extraction cleaning bearings and crankcases
Reassembly of the new engine bearings
And reassembling the vilolebrequin and the gearbox
Then winding cylinders and pistons
And then we put everything in the crankcase
Et voilà  ;D
We will submit its engine
motolocopat
Cool. .. that you can dive in and rip it apart then reassemble. How long did it take?
