M620 Clutch
Started by Mother, August 09, 2015, 11:30:17 PM
Mother
Are 05/06 wet clutch plates compatible with a 02/03?
found my old skin suit
Mother
#1
02/03 Barnett part# 306.25.10001
9 friction and 8 steel plates
Kevlar
05/06 Barnett part# 306.25.20005
11 friction and 10 steel plates
Carbon Fiber
But
Are the plates the same?
Could I get the 05/06 plate kit and just load my basket until it's full and call it good?
Quote from: Mother on August 09, 2015, 11:30:17 PM
No, '05-'06 are APTC 'slipper' clutches, different diameter from '02-'03, which are the standard wet clutch plates as fitted to '04 and earlier small-case engines.
Cloner
Barnette wet clutches suck.  I'll never use another set.  They drag like mad.
My two cents have been contributed to this topic.  We now return you to your regularly scheduled program, already in progress.
'64 Ducati Monza 250
'00 Aprilia RSV Mille
'03 Ducati 800 SS (race bike)
'04 KTM 450 EXC
Quote from: Cloner on August 10, 2015, 09:43:14 AM
My experience as well, based on a single sample, at least for Ducati.
Oddly, I used several sets of Barnett plates for a Yamaha many moons ago, and they were stellar.
Unfortunately I had to eat that one Ducati set.
I knew the Barnett dry clutches for Ducs  sucked, and had good experiences with their wet plates in the past.
Good to know.
Mother
To what degree do they suck?
This isn't a race bike, it isn't even a go fast on group rides bike.
I just want the damn thing to go forward
I think they're saying you won't be happy with the drag.
Mother
Having never experienced that problem before
Seems like that should be a correctable issue and not necessarily a result of the plates themselves
maybe wear of another component?
I'm speculating of course but an engaged clutch shouldn't drag unless something is preventing the engagement
I think since two fairly well respected Ducati techs are telling you that in their experience they drag and when they installed an OEM stack the problem disappeared...
I'd tend to listen.
I agree, if everything is in tolerance it should disengage and not drag. I don't know if the bikes in question had aftermarket slave cylinders that shortened the pushrod travel causing the drag, or if the manufacturing tolerances on the Barnett plates is such that they just don't work.
Maybe Nick or Cloner will add some info.
Mother
#10
Agreed and not questioning their epertise, just the sample size of their experience ... on second thought, not even that
I'm curious to the degree of drag
does applying a brake stop the creep?
Did it drag bad enough to kill the engine with brake application?
If so, is drag that bad an indicator, like you mentioned, of non compatible aftermarket components or of other worn parts
S2R800, so it was an APTC clutch.
OEM master and slave cylinder.
OEM clutch slipping at 34.7k miles.
Replaced OEM plates with Barnett 306-25-20005.
It dragged so bad that it was totally impossible to find neutral when stopped with the engine running.
Fundamentally unacceptable.
Customer was game to try it for a while to see if they bedded in or whatever.
At 42.1k miles they were still dragging, and he had reached his limit.
Replaced them with an OEM set, and no dragging.
Motul 3000 oil for the entire time.
I serviced that bike from 17k miles to 56k miles, over a 4 1/2 year period.
The only time the clutch dragged was when the Barnett plates were in it.
Besides the pure aggravation of it, I've spent $350 in parts and labor to have a useless set of plates on my shelf.
They don't fit any bike I have, so I can't experiment with them.
I see no reason to continue experimentation, even at only my expense, when I've got a perfectly satisfactory solution (OEM plates).
But, all that aside, I think you should buy a set, and install them.
Let us know how they work.
Mother
#12
the snark is strong with you two this afternoon
I do appreciate the information
Quote from: Mother on August 10, 2015, 02:50:19 PM
Snark...us?
...and besides...
it's only an $80 price difference.
If you can live with finding neutral on the coast then go for it.
Ducs haven't gotten any cheaper to own. :-\
Makes you wonder about issues like overall stack heights and the relative width of plates. Is it possible to mix and match plates to set stack height and avoid clutch drag, or is the Barnett friction material the problem? You blokes have any tips there?
Tuning the clutch is a real pain with the wet clutch set up. With dry clutches I have been mixing Barnett and oem parts to get the result I want, but thats easy on a 900.
