2007 S4R starter motor
Started by Shanski, August 10, 2015, 07:28:44 PM
Shanski
Hi all,
I'm sure someone has had this issue as well so apologies if this has already been answered.
I have an S4R 2007, low miles (3000) and recently I've had a reoccurring but intermittent issue with my starter.  It seems that every time I go for a ride there's a chance when I pull up or stop somewhere it might not start again. At least for 10 or 15 min.
So I have power, battery has been tested, it's not the relay,  it's not the stand, it's not the earth (because this model has shit earthing along with a shit starter [roll] ) because I added an earth. It seems to do this only when the starter is hot or left in direct sunlight. I usually have to put the bike in the shade and wait. Eventually it starts as if there was never a problem.
I usually get home then stop and start it all I can with no issues. So I can't trust the bike when I go anywhere, at least not if I want to leave when I decide.
So I can just replace the starter of course but they're pricey new ($600 USD) and secondhand is not really trustworthy for me.
Anyone experienced this issue? Solution (apart from starter replacement)
You might need a starter, but probably not.  The starters are actually pretty damn rugged.  First you want to eliminate the possibility of bad connections.
https://www.bing.com/videos/search?q=starter+circuit+voltage+drop&FORM=VIRE1#view=detail&mid=167BA5C5ACAFCBD27DD6167BA5C5ACAFCBD27DD6   This is for a car, but same method.  Best done while the bike is not cranking properly.
Cheaper starters:
http://ricksmotorsportelectrics.com/starter-motors
http://www.electricmotorsvc.com/
silas
I have 2 extra starters. They have been recently confirmed that they work and were off a mid 90's 900SS. Most likely the same starter as on your bike, but double check first. How about $75 for one + shipping? I can send pics later if desired.
Ride fast, ride safe
'98 M900, '92 Yamaha TDM850
oldndumb
All experiences are not equal or necessarily similar but I had a starter problem which only manifested itself when hot. I dicked around a bit before deciding to do an Amp draw. The results were high enough to be quite scary, 400Amps. Sears has a very reasonably priced DVOM with a high Amp range for around $55.00. Another consideration is taking it to an Auto electric shop and have them do the test with it at operating temp.
Quote from: oldndumb on August 11, 2015, 07:34:46 AM
Quite the definitive test, assuming the drag is not the engine itself.  Normal draw would be around 90 amps.
