Hard deceleration as soon as I let off the throttle ...
Started by AudiFan, August 19, 2015, 08:33:47 PM
AudiFan
While riding esp in the city when I let off the throttle my bike decelerates extremely hard basically bucking me forward unless I pull the clutch.  It's sort of an extreme engine break.
Ok so I do not have a clue how to correct this or if this is normal for the S2RD.  I used to own a S4R and can not recall this issue with that or any other motorcycle I have owned.
Kopfjager
Normal. But wouldnt hurt to make sure your brakes arent dragging
EEL
Please specify what gear you experience this in. If you are having this in first, it might not be an issue. If sixth, I would be cautious and do some inspections. If you have a front and rear stand, run the wheels off the ground and see if there is significant drag
Any lightened flywheel mods to disclose? This will make engine braking even worse.
Fix? Do you have a powercommander? Try putting 5 percent down the entire vertical column in 2% throttle position ( or whichever is the one higher than 0% throttle). I was messing around with my fueling and found that engine braking changed by doing a minor fuel tweak in the column noted.
AudiFan
I usually experience it from 1st and 2nd gear and that is usually at lower speeds. It makes riding through a parking lot or 2-up annoying as @#$%.  I do not have a PC or any other  engine mods.  I do have a bit of brake drag but this is definitely due to brake drag.
Thanks for the replies though.  Guess I just need to live with it and work that clutch.
scaudill
I have the same happening with my M750.  I think part of the problem is with the throttle assy or carburetors.
I had a 1200 H-D Sportster that should have great engine braking, but never experienced the abrupt decel like the Ducati.
Worst thing in the world on ducs is msf course at 10mph. On off trhttole rolls head back and forth until you learn clutch control. I still forget riding 2 up to be smoother on the clutch. My smacks my helmet on a bad downshift.
AudiFan
I just really don't remember my S4R being this bad.  Oh well I will get used to it I hope....
Quote from: scaudill on August 20, 2015, 05:06:26 AM
Lower compression, lower RPM, heavier flywheel.
SpikeC
 Make sure that your right foot does not contact your brake pedal when you ride. I had a friend many years ago who kept burning shift forks in his Honda, he had his foot just above the shift lever when he rode, and it would contact the lever just enough that he did not notice it, but the bike did!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
Blackout
I love the engine braking effect of the Ducati. It makes me a better mountain rider. Hang onto the bike with your knees not just your hands.
2003 Ducati Monster 1000
2003 Honda CR250
2008 KTM 990 SuperDuke
SwiftTone
Quote from: Blackout on September 29, 2015, 10:22:57 AM
I asked my track day instructor about this because I was basically relying on engine braking to slow down for corners and almkst not using my brakes at all. He advised me to use my (front) brakes more because engine braking slows down the bike with the rear wheel and can create instability. Front braking stabilizes the bike. It might be fine up to a certain pace but as the pace picks up you want to be able to modulate braking with actual brakes.
