redsc1
« on: August 30, 2015, 05:20:07 PM » |
Hi
Just wanted to know what your opinion of bar end mirrors verses standard handle bar mounted mirrors is? Those that have used both – which one gave you a better rear view? Which do you prefer now?
Simon
2014 Ducati Monster 659
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Moderator
Often wrong. Never in doubt.
« Reply #1 on: August 30, 2015, 05:44:55 PM » |
Hmmm.. well there's bar-end mirrors and then there's bar-end mirrors..... Best mirrors I have ever used for the quality of your actual rearwards visibility is Rizoma's Class Retros. I use conventionally mounted mirrors now - coz I'm vain and shallow and like the look better - but as functional mirrors the Class Retro bar-ends take some beating IMO. http://www.monsterparts.com/pc/BS144/Mirrors/BS144.html
Ducati 1100S Monster + Ducati 1260ST Multistrada + Moto Guzzi Griso 1200SE
Dochunt
« Reply #2 on: August 31, 2015, 02:18:49 PM » |
I put on CRG bar-end mirror on Rizoma weighted bar ends on the 796. Much better view and zero viberations in the mirrors and the handle bars.
Aprilia Caponord 1200 2015 M796 ABS 2012 Triumph thunderbird Sport 1998
redsc1
« Reply #3 on: August 31, 2015, 11:59:50 PM » |
Thanks guys. I think I might get a pair of the Rizoma Circuit 851's
StephenC
« Reply #4 on: September 01, 2015, 01:51:09 AM » |
I've been running Rizoma Reverse Retro's (bar end) mirrors for years now and love them. Unlike Ung, I prefer the look. The view is probably not as good as the original mirrors, but at least it stays still (no vibration). You get used to ducking your head a little and tucking your elbow in but what you then see is lovely and clear.
Ducati Monster 1100S (2009)
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Moderator
« Reply #5 on: September 01, 2015, 03:07:17 AM » |
redsc1, all three of us who responded so far, seem to agree that good bar-end mirrors (and we're all reporting from FHE) offer better rearward vision than standard mount mirrors. I have to tuck my elbows in to see what's behind me now..... no big deal, but it wasn't an issue at all when I had the bar-ends. I like the look of Rizoma Reverse Retro bar-ends that StephenC is running better than the Rizoma Class Retros which I once had. But they're smaller, so the rearward view has gotta be lessened too. Form vs function...... have fun deciding which means more to you
StephenC
« Reply #6 on: September 01, 2015, 03:23:55 PM » |
It is also worth noting that I have mine pointing in but they could easily be flipped the other way and would likely negate all the angle of view issues (albeit minor) that I mentioned. This suits me as 1. I'm all about form and stuff function and 2. I lane split and want a narrow bike!
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Moderator
« Reply #7 on: September 01, 2015, 07:17:27 PM » |
^^ Looking good
loony888
« Reply #8 on: September 02, 2015, 01:20:57 AM » |
CRG lanesplitters 3" convex glass so you get a great rear view, folding so you can tuck them in when lane splitting and the quality of them is exceptional. i've used them for years and couldn't go back to mickey mouse ears on a naked bike, no vibrations and they look very cool.
HERE AND NOW 12 DIAVEL AMG 93 888 RS 09 1098R BAYLISS 07 Husqvarna TE 450
GONE BUT NOT FORGOTTEN 03 S4R 95 900SL 01 S4 93 900M 96 748SP
StephenC
« Reply #9 on: September 02, 2015, 03:50:36 AM » |
^^ Looking good Thank you. The new seat should arrive soon and I'm done (for now!).
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Moderator
« Reply #10 on: September 02, 2015, 03:52:50 AM » |
"for now" Done is never
StephenC
« Reply #11 on: September 03, 2015, 02:04:58 PM » |
But where to go next...?
I may have to replace my fluid reservoirs as the ones I have seem to be leaking - I need the bike back on the road (no seat at present) to check them. I guess I will be due a chain and sprocket replacement soon. I'd love to do a Motogadget instrument upgrade, but that sounds like far to much work!
Betty
« Reply #12 on: September 04, 2015, 12:03:09 PM » |
Hi
Simon
I think bar ends provide a much better view ... but I have only used ones that are mounted on the end, sitting out. They are clear of your body so they provide an unobstructed view + with the right curvature of the glass you can see a lot more ... the Boss now uses them after much resistance and loves them. I still use (rather expensive) handlebar mounted mirrors ... the vision provided is OK which typically gives me a clear view of some part of my jacket. The bar ends don't need to be expensive to be effective either. You can probably still buy a cheap set from China delivered to your door for less than the cost of delivery alone for a 'quality set' of name brand mirrors. It is probably even worth the minimal expense as a trial - I know some people that have kept their cheap trial set for years ... still solid and providing a great view. Plus they are cheaper to replace if something unexpected happens. Folding bar end mirrors will allow you to tuck them in to narrow the width of the bike and push straight back to their previous position when clear of obstructions, but your bike will likely be wider regardless (depending on the bar end arrangement before/after).
« Reply #13 on: September 04, 2015, 04:49:53 PM » |
Bar ends are good for bars that are higher but ifnyou have a lower bar or clipons its too much head movement. I foundnwith stock bar and clipons i had to move head toonmuchband actually was unsafe. Now with higher bars they work great.
StephenC
« Reply #14 on: September 04, 2015, 06:19:21 PM » |
Some people run token mirrors on their clip-ons, more their to satisfy the law than to actually see behind you. Personally I like to know what's going on around me.
