January 04, 2025, 01:14:21 AM
Rotors: What do I have? Guides?
Topic: Rotors: What do I have? Guides? (Read 2573 times)
Heath
September 02, 2015, 12:01:11 PM »
I have googled unsuccessfully to find some sort of guide to Brembo Rotors or any rotors for that matter. I always see people commenting rotor X is better than Y but have never seen a write up for this.
Here are pictures of what I have. I need to decide what I am keeping and what I am selling. I think they are the same size rotors but honestly do not know for sure. Both have no markings other than the Min 4.00mm mark on them. Both are 5 bolt rotors.
Which rotors here are better?
Also is there a good write up out there so I can be more educated on rotors/brakes?
Silver carrier, with full floating buttons from TPO added by previous owner.
Black carrier, OEM from a Hypermotard 1100S
2007 Ducati Monster S4RT
Re: Rotors: What do I have? Guides?
September 02, 2015, 12:10:57 PM »
IMO, no functional difference between those rotors, other than the floating buttons.
There may be offset differences, I've seen some wackyness in the 5-bolt stuff.
Heath
Re:
September 04, 2015, 05:58:52 AM »
What's the easiest way to tell the offset?
Nibor
insanity far outweighs horsepower
September 07, 2015, 05:19:44 AM »
Place a flat edge like a ruler across the face of the rotor, then measure the offset between said edge, and the carrier. Voila, offset measured.
Re:
September 07, 2015, 05:47:47 AM »
I like the old style click clack of full floaters.
Heath
September 08, 2015, 10:21:54 AM »
Looks like this is going to be a no brainer. The silver rotors are 15mm that I need and the black are 10mm. I did find out the full floating buttons don't have the correct shims though. No wonder they were so loose.
Re:
September 08, 2015, 11:29:33 AM »
Full floaters have no shims. Semi floaters have shims
Re:
September 08, 2015, 11:30:09 AM »
Full floaters are tambourines basically
Re:
September 08, 2015, 11:58:49 AM »
Quote from: Raux on September 08, 2015, 11:29:33 AM
Aftermarket buttons, like STM or Corse Dynamics, for full floaters use shims because there are two thicknesses of rotor blades and only one length button. The shim, or washer, also protects the clip.
http://motowheels.com/i-7579497-corse-dynamics-full-floating-rotor-button.html
Heath
Re:
September 10, 2015, 01:49:05 PM »
Seeing as they are 4.5mm rotors I'll be switching from a 0.5mm shim to a 1mm shim. They should still be loose once it's done.
September 10, 2015, 01:59:31 PM »
Dunno what shims you've found, but there's some here:
http://www.mcmaster.com/#standard-metric-shims/=yvryov
Heath
Re: Re: Rotors: What do I have? Guides?
September 11, 2015, 10:57:00 AM »
Quote from: Speeddog on September 10, 2015, 01:59:31 PM
Thanks, that is where I ordered them from. I couldn't find anything local. Should get here Monday.
Heath
Re:
September 15, 2015, 08:02:11 AM »
I got the 14mm x 20mm x 1mm stainless steel shims from McMaster-Carr (see Speeddogs post). They fit perfect like it should have been in the first place. Still full floating and kept that tambourine sound. I might anodized the carriers this winter. For now I want to get my bike back up so I can ride.
