January 04, 2025, 01:15:24 AM
Clip ons on a M796
Topic: Clip ons on a M796 (Read 2279 times)
Dochunt
Clip ons on a M796
September 04, 2015, 04:57:18 PM »
So.
When I got this bike in April I thought the at my age I did not want a sport bike and wanted some thing with a more "standard" upright seating position. 2000 miles later.
I now find myself wanting a more "sport bike" type posture.
I removed the bar risers and I am now thinking of putting on clip ons.
Any advise re: cost, pros and cons, things to watch out for and how to go about this will be greatly appreciated.
Thanks
Aprilia Caponord 1200 2015
M796 ABS 2012
Triumph thunderbird Sport 1998
SpikeC
Spike in PDX
Re: Clip ons on a M796
September 05, 2015, 10:17:58 AM »
Speedy Moto does a nice set for that Monster, and they are adjustable. Pretty easy installation as well.
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
Dochunt
September 05, 2015, 01:08:58 PM »
Great. Will check it out. Thanks
M796 ABS 2012
September 05, 2015, 03:32:57 PM »
Watch for clearance between your coffin masters and the part of the clipon that clamps the bar.
Most require a spacer for each master.
See what clearance you've got between the fork leg and the frame at full lock, some clipons are bulky there, and will interfere with the frame.
Same for clearance between the fork leg and the headlight assembly.
Clearance between the clipon and the upper triple.
Where are the brake and clutch lines going to go, is there room for them?
The ModFather
Duck Off
Monster Magnet
September 05, 2015, 05:01:18 PM »
Woodcraft makes a nice set that doesnt require removal of the top triple and you can buy different heights as well so I started with 3" rise and dropped to 1" rise about 2 years later.
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
GreasySnipe
September 05, 2015, 05:37:47 PM »
Aside from what others have noted, be aware there are plastic locating pins on your switches that align to holes in the bars. What ever clip on bars you get probably won't be drilled, you can go 2 routes with this. The first and what I did was make a tape template of the location of the holes on the OEM bar and drill with the correct sized drill rod or the second, where you cut the locating pin off the switch and use tape under the switch. One more thing to consider is the new riding position on your lower back, When I did mine I bought some used 848 clip ons (I have the Showa adjustable Forks installed so this may not be an option) from flea bay and had to modify them as some of the bolt lugs interfered with the coffin master (see Speeddog's post). I found this was a cheap way to verify whether I would like the new riding position before I invested in some expensive parts.
Last Edit: September 05, 2015, 05:39:44 PM by GreasySnipe
Re:
September 05, 2015, 05:51:39 PM »
I went with woodcraft with the 1 inch longer bar option, I did switch out to pee cup masters though, but spacers work too. I also had zero rise under the triple...loved the stance, but have a strong core...and surprisingly the stock seat was better for this setup, didnt try a low seat but imagine it would have been better. Gel seat made the angle too much, with too much weight on wrists. Also to avoid long throttle twists go with quick cam throttle cams, electrean I think is how you spell it.
I just deleted tabs and pins...scared to drill aluminum bars.
S2R 800 '07
September 05, 2015, 06:44:24 PM »
The fast throttle cams are "Electraeon"
For added space behind the headlight (brake lines, clip on parts or whatever)
http://www.desmoworld.com/shop/ducati-monster/m696-m796-m1100/elektrik/scheinwerfer/desmoworld-m696-796-1100-1100evo-headlight-relocator.html
Spacers
http://www.monsterparts.com/pc/ADAP/Bar-Acc/ADAP.html
Dochunt
September 06, 2015, 05:00:27 AM »
Great advices.
Thanks to all.
Looks like I have some more planning and studying to do.
I am also going to modify the stock seat so it is flatter and I can sit further back on it and keep the weight more balanced between the butt, feet and wrists.
M796 ABS 2012
SpikeC
Spike in PDX
September 07, 2015, 11:09:00 AM »
I have the Woodcraft clipons on my bike, 2" rise which is just about at the top clamp. I love them, and I am 66 years old, so you young whippersnappers should shut up about bars being to low!!
Spike Cornelius
PDX
1965 T100SC
Dochunt
September 07, 2015, 12:50:19 PM »
Quote from: SpikeC on September 07, 2015, 11:09:00 AM
You are an inspiration
M796 ABS 2012
The ModFather
Duck Off
Monster Magnet
September 09, 2015, 03:03:01 PM »
Drilling the bars aint too bad. You just need to mark where you want it ( I measured where the nub was on the inside of the switches from the end of the switches and put masking tape on the bars where the switches ended and measured in from there on the bars) The key to drilling in the bars is to have a guide for the bit to sit in. I put a piece of masking tape on the bar made the mark on it took a nail and hammered it into the mark a couple times to make a small indent in the bar this was enough of a guide for the drill bit to stay in place while drilling. Then you take all the tape off.
2008 848 Track Bike
Dochunt
September 09, 2015, 05:30:35 PM »
Good idea.
Will give it a try.
This will be a winter project once the snow lands in NJ.
Will ride as much as possible for now
M796 ABS 2012
