January 04, 2025, 12:29:54 AM
Please Help
Aftermarket/ other model headlights on the Monster
Topic: Aftermarket/ other model headlights on the Monster (Read 6661 times)
Alexandre
Monstro
July 15, 2008, 08:58:17 PM »
As much as I like the classic look of the round light on the front of my bike, I am curious to see some options.
I know one person has a KTM duke headlight and another person had something like cyclops somthingorother...?
I also love the one that looks like its from a 999 but is really some custom bit from a lambo...
can we see some pics here?
thanks!
Alexandre
Wanwo
Re: Aftermarket/ other model headlights on the Monster
July 16, 2008, 09:33:47 AM »
A few images I have on file. The last one is mine. The headlight was inspired by a bike of Norm's but I've since gone back to the stock lamp, as well as many other changes since that pic.
herm
July 16, 2008, 01:22:06 PM »
here yah go...
i know, very triumph.
but they are for sale
michalik_piotr
July 17, 2008, 09:30:06 AM »
Thats an Acerbis "Cyclops" headlight. I've had the same light for about 2yrs or so now and trying to figure out how to wire in an HID kit, anyone done it? Help.... thanks. I keep blowing fuses!
squidwood
July 17, 2008, 09:15:13 PM »
cyclops headlamp is great until you need to see in the dark!
I had one fitted for about a year, but does not put out enough light for me.I am old, blind and live way out in the boonies where there are no streetlights.Went back to the stock light, but looking for something different that puts out light, without going HID .
July 17, 2008, 09:32:51 PM »
Quote from: michalik_piotr on July 17, 2008, 09:30:06 AM
Which fuse do you blow, and how do you have it set up? All you need is an H3 HID bulb, a ballast w/ignitor (built in preferably) plug and play. That cyclops headlight looks awesome, just wish it was a bit bigger.
michalik_piotr
July 18, 2008, 08:25:53 AM »
i keep blowing the 7.5 fuse....i think its the headlight, tail, turn sig one.... (ugh, i should have remembered which one...it was the second from the top after the big 30amp blue one... it was a 7.5. ugh, bad memory!
i have it wired up the only way it would wire up.... connected all the wires to each other the way they should.
i tried grounding the hid through the frame, through the headlight housing and directly off the neg on the battery and still blew that fuse.... its a the 55k kit but i don't think that should matter as i'm only running either the low or hight at a time not together.
michalik_piotr
July 18, 2008, 08:34:48 AM »
ok, to cut down on the confusion and for me to avoid duplicating responses pls see the original thread i posted on this toppic: HID H3 kit wireing help into an Acerbis Cyclops. Thanks for the help guys.
c_rex
Quick! Into the transmogrifier!
August 26, 2008, 07:22:28 PM »
adding a pic to this thread. replaced my Acerbis Cyclops with a KTM SuperDuke unit (cr: Brownwhale). The KTM is loads brighter than both the stock light or the Acerbis. Wiring was pretty much straight across.
truckinduc
August 26, 2008, 07:31:52 PM »
c_rex
August 26, 2008, 08:07:55 PM »
I fully expect to see your kneecap adorning the gas cap now.
love the radiator btw!
DesmonsterS4RS
"The Desmodromic Symphony"
August 26, 2008, 08:45:24 PM »
Quote from: truckinduc on August 26, 2008, 07:31:52 PM
Always something original, I like your style
07 S4RS, Full Arrows (CF), DP ECU, Open Airbox, K&N, Speedymoto Gold "Kukri" PP, Rizoma Clutch Cover, DP Gel Seat, Cookies1 Tail Chop, 14 Tooth Front Sprocket, CRG LS, Dyno Tuned by AMS 132rwhp, 74 lb ft.
