Termi rear header removal issue
Started by ducman82, October 08, 2015, 03:49:52 PM
ducman82
 2008 S4RS , Rear header is a BEAR to get out. i have no idea how they got it in. SO, i tried removing the ride adjuster rod, and that did not work, so now i can't get that bolt lined back up.
how hard is it to remove the rear shock assembly? can i just remove the top pivot to scoot the whole thing back the 1/8th of an inch i need to get that headers out? or is it all under some kind of pre load? or can i just move the upper pivot bolt?
ducman82
hooked the rear subframe up to the rafters! HA HA!   got it
