January 19, 2025, 01:15:23 PM *
Author Topic: Moonster 620 PC III install  (Read 2214 times)
POCO LOCO
« on: October 20, 2015, 01:38:53 PM »
Would by chance a PCIII  installed on top of the battery (as per PC instructions) give any clearance issues when gas tank is lowered ?
S2R 800 '07
« Reply #1 on: October 20, 2015, 01:44:35 PM »
I have a PCIII on my battery - S2R800 - velcro to keep it from sliding around and secured by the rubber strap.
Can't imagine there being less space on a 620
« Reply #2 on: October 20, 2015, 01:46:22 PM »
Both plastic tanks?
steel?
POCO LOCO
« Reply #3 on: October 20, 2015, 01:49:01 PM »
A 2006 Monster 620 has a plastic tank.
« Reply #4 on: October 20, 2015, 01:53:46 PM »
I realize that.
The earlier bikes had steel, and you didn't say what year until now.
Isn't the pump flange directly above the battery?
Dirty Duc
I'd rather be an anti-
« Reply #5 on: October 20, 2015, 02:05:23 PM »
No, the flange is directly behind the battery.
« Reply #6 on: October 20, 2015, 02:17:17 PM »
Then the PCIII should fit.
« Reply #7 on: October 20, 2015, 03:35:20 PM »
There may be a clearance issue with the under tank padding. On my S2R1000, I had to remove that to have enough room for the PCIII on top of the battery.
S2R 800 '07
« Reply #8 on: October 20, 2015, 03:49:54 PM »
Mine is gone too  waytogo
Maybe not an issue on the 620, but if it is, remove it or cut an opening where the PCIII is.
« Reply #9 on: October 20, 2015, 05:01:48 PM »
PCIII did not fit in my S2R1000 in that location. I placed it in front of the batter behind the airbox (which now has PODS). I dont run a PCIII anymore.
POCO LOCO
« Reply #10 on: October 21, 2015, 04:01:22 PM »
Removed the padding from under the tank which is held in place by velcro, and now the PC has enough room.
« Reply #11 on: October 21, 2015, 04:06:22 PM »
 waytogo Dolph
Omnipotent Potentate
Personal Pretext
« Reply #12 on: November 12, 2015, 06:10:06 AM »
Had a PCIII installed on my '06 620 per the instructions. Everything was fine
