September 06, 2024, 10:16:04 PM
Throttle sticks after riding in the rain
Topic: Throttle sticks after riding in the rain (Read 1132 times)
Dragsterhund
Sonic Reducer
July 16, 2008, 07:31:00 AM »
So, I rode home in torrential downpours on sunday for like 3 hours...really really heavy rain. Not the smartest thing I've ever done, but anyways... I got on the bike today to ride to work and lo and behold, the throttle sticks open. like doesn't close AT ALL, and opening the throttle is difficult. Has anyone else had this problem after riding in the rain? Where should I start? Throttle bodies? Throttle assembly at the bars? Just hit it with some cable lube? If I have to lube the throttle bodies, what kind of lube should I use for that?
2003 Ducati Monster 800S i.e.
1999 Ducati 748S Track Bike
2011 Ducati 848 Track Bike (Ex Jake Holden AMA DSB bike)
1967 Ducati Monza 250
2008 Yamaha TTR 125
1973 Honda CB450 (Sold)
1972 Honda CB450 (Sold)
2002 Suzuki SV650 Track Bike (SOLD!)
1994 Kawasaki EX500 (SOLD!)
Omnipotent Potentate
Personal Pretext
Re: Throttle sticks after riding in the rain
July 16, 2008, 07:58:43 AM »
Start simple and work to hard. So check on the assembly at the bars and while you've got the cable free from the tube, see if just the tube sticks
Next you could disconnect the cable from the cam at the throttle bodies and see of the cam will move freely once the cable it detached.
By separating the sub systems, you can home in on the problem area. If it turns out the be the cable, I've got some cable specific lube and one of those clamp on gizmos to force the spray into the cable.
Dragsterhund
Sonic Reducer
July 16, 2008, 08:59:38 AM »
Cool... if you swing by your house before rhodeside, could you bring it to rhodeside tonight?
2008 Yamaha TTR 125
Personal Pretext
July 16, 2008, 09:19:12 AM »
Quote from: Dragsterhund on July 16, 2008, 08:59:38 AM
I'll probably be on the later side since I need to run an errand 1st. But I can bring the lube and gizmo... Hmm that sounds so wrong.
gnostic203
Lost in Cyber Space
July 16, 2008, 12:25:45 PM »
This is probably not the case but... I was riding home from a 100 mile ride the other day when my throttle wouldn't snap back and became tough to twist. I pulled over and believe it or not the grip had slid off the throttle just enough to rub against the bar end making a friction point.
Probably too easy but like yuu said start with the simple.
