Will a 2011 848 Clutch Cover Fit a 2001 M400?
Started by MonsterMadMarty, November 07, 2015, 01:50:51 PM
MonsterMadMarty
Dear Guru's of this forum,
I have a damaged clutch cover on a 2001 M400,  I also have a 2011 848 clutch cover. Apart from the obvious difference in where the oil filler is placed will it fit & does the oil filler being where it is make any difference?
If it helps the 848 cover has the part number: 243.3.103.1A - AI & the box it came in has part number: 24321181EE
Cheers in advance  [thumbsup]
The 848 clutch cover:
The damaged M400 cover:
I've not tried it, but AFAIK, all of the interfaces are the same.
I'd expect it to work fine.
Oil filler move was only for accessibility on the SBK, no effect on function.
The 848 clutch is smaller (diameter) than the Monster clutches, but I don't know if that means there's a problem...
