Fuel pumps and rebuild kits for carbed Monsters.
Started by koko64, November 21, 2015, 12:52:20 PM
If you need to rebuild or replace your oem vacuum fuel pump you can now get parts local at a decent price from Mikunioz.com.
Ducati dealer in Melb told me I bought the last oem fuel pump in stock in the country and no rebuild kits were available.
It seems someone is now a direct importer for rebuild kits, etc. The oem single outlet pumps (65LPH) are no longer available except for nos overseas. The single outlet pump is superseded by a twin outlet pump which uses the same rebuild kit.
Oh I almost forgot, CCW has the rectangle pump available too. It flows 14 LPH, enough to run stock CV carbs and is easy to hide.
Cheers.
GK
Helpful info koko! Thanks for sharing it! ðŸ'ðŸ»
2001 Ducati  Monster 900S ie
Gone but not forgotten!
