January 09, 2025, 08:42:50 AM *
Pages: 1 2 [3]   Go Down
Author Topic: Fantasy Ducati Thumper  (Read 4880 times)
Dirty Duc
I'd rather be an anti-
« Reply #30 on: January 01, 2016, 12:58:36 PM »
Well, the original spec said 60hp... Leaning toward watercooled.
None over the large case stuff seems to fit the small cases.
Re:
« Reply #31 on: January 01, 2016, 01:30:47 PM »
http://m.ebay.com/itm/Ducati-749-999-Motor-Engine-Case-Block-OOS-/380394406243?nav=SEARCH
« Reply #32 on: January 03, 2016, 05:40:13 AM »
I think for the supermono it made sense to keep the weight down low.
For a scrambler...   I'd put the horizontal head on the vertical cylinder move the plant up and forward in a shallow sump case.
I would use small end located piston, and just run balance on the flywheel... Harmonic damper or whatever.
The problem with the supermono design is width.
Have a look at one of the old singles.  They are absurdly narrow.
Re:
« Reply #33 on: January 03, 2016, 07:45:54 AM »
The frame bends inward where the vert cyl was.
Pages: 1 2 [3]   Go Up
