Cleaning Termi Stainless Steel Pipes?
Started by nickbee, December 31, 2015, 12:38:27 PM
nickbee
So I just took off my Full term exhaust to install carbon belt covers on my M1200S.
Do you guys have a preferred way to clean stainless pipes?  I remember on my RC51 Ti Satos I used to use a scotch pad with orange cleaner.
Heath
I had good luck with green scotch brite pads and bar keepers friend.
2007 Ducati Monster S4RT
nickbee
I use bar keepers friend all the time on my all clad stainless pans/pots so that makes perfect sense!   [thumbsup]
d3vi@nt
'13 MTS GT
'99 ST2
'07 M695 - Sold
xcanuc
I used to use simichrome on my 900ss. Worked amazing.
Boltznnuts
great results using Raco,just to add another product to the fold
Mothers Metal Polish and Turtlewax Metal Polish both appear to work well. They are both that white paste common to such metal polishes. A Scotchbrite too.
lazylightnin717
Scotch brite and WD 40 has worked well for me.
Comes a time
Says don't you see
Gotta' make it somehow
CookieMonster
Quote from: lazylightnin717 on January 03, 2016, 02:38:41 PM
I have heard of this method as well...also I don't know how true this is but that it helps with the bluing process for those into it. Not my statement, so don't flame me for it if not accurate.
"Friend don't let friends ride stock"
-S2R1k 992 DESMO LIFE
FWIW I used a "sand blaster" disc in a grinder to quickly clean off the worst stuff (on 2000 era pipes) and a fine wire cup in a drill for follow on passes as well as concave areas the disc could not do at all.
