M695 exhaust connectors
Started by cencalal, February 26, 2016, 07:09:06 PM
cencalal
I've got a pair of 2" inlet oval mufflers that will work on the little monster, if I could find some connector pipes.  These were close...
http://www.ebay.com/itm/Viper-Ducati-600-Monster-95-03-Motorcycle-Stainless-Steel-Connecting-Mid-Pipe-/131437839377?vxp=mtr&hash=item1e9a4e4411
...correct diameter at both ends (42mm/48mm o.d.) and about the right length (8 1/2"), but weren't bent quite enough at the back, so the cans were angled out at the rear.  I'll check with a muffler shop to see if they can bend 'em a bit more, but in case that doesn't work, can anyone direct me to some that are the right bend for the M695?
Thanks
cencalal
The above kit worked ok - could have had the connectors made locally in stainless for about $75, but I was able to bend these (and my stock header outlets) enough for a decent fit.  And with the included clamps and hangers this was a good deal - sometimes this Chinese stuff is ok.
Not much of a performance boost, but I put on a FatDuc at the same time and have to adjust that yet...
Anyway, the Micron titanium and stainless cans took off twelve pounds and now I'm hearing the music.  [thumbsup]
