January 04, 2025, 01:57:41 AM *
News: Please Help
Pages: 1 [2]   Go Down
Author Topic: My 5 month project  (Read 3400 times)
« Reply #15 on: March 06, 2016, 08:30:42 PM »
Install the flapper valve under the oil filter stud.  Use a properly sized socket that has had the leading edge radius ground off as that stud is VERY thin.
I'd go engine, turbo, cooler & then back if it were me
 waytogo
Dirty Duc
I'd rather be an anti-
« Reply #16 on: March 06, 2016, 08:47:34 PM »
I second Stew's routing.
« Reply #17 on: March 06, 2016, 08:52:40 PM »
Don't all of the turbo units get their pressurized oil from a gallery, and that oil is gravity drained back to the sump?
In that case the turbo oil is just bled off, so not much difference between the before/after the cooler issue.
Definitely needs an oil cooler, and keep in mind what Duck-Stew said about maybe two coolers.
Dirty Duc
« Reply #18 on: March 06, 2016, 08:59:28 PM »
Only on the ones that are mounted higher than the oil level in the sump.  A turbo mounted under the swingarm (unless it is a sealed unit like the Airesearch Bill Johnson used) needs a scavenge pump to keep up the oil flow.  Otherwise you can kill the turbo with coked oil in the bearing/bushing.
Pages: 1 [2]   Go Up
