January 01, 2025, 09:04:15 AM
chinese CNC short levers...AVOID!
Topic: chinese CNC short levers...AVOID! (Read 3036 times)
samuraibiker
if you don`t someone else will
but it goes to 11
April 07, 2016, 03:58:34 PM »
bought some chinese short CNC levers for my monster... all ok for a short time but then after being stuck in a traffic jam, the clutch started slipping.... was a real pain to get home. Damn, clutch repair needed I thought
did some digging around on the net...turned out the CNC levers sold on ebay from chinese sellers is the problem..many other bike riders had the same problem....... switched back to the original OEM brembo levers.... all ok and no slipping....
my two cents but avoid chinese CNC levers at all costs!
Mike
monster 400 evolving into a 900; vespa px150, vespa gs 150, suzuki grasstracker 250 60s custom tracker, honda cbr1000rr
Re: chinese CNC short levers...AVOID!
April 07, 2016, 04:04:17 PM »
Had a customer with a Busa who got very cheap billet levers. They rattled to the point of falling off.
He got Pazzo or CRG after that.
I have worked on Chinese dirt bike, once.
China makes great stuff
if they want to
mr.freezer
April 10, 2016, 11:07:57 PM »
i have chinese CNC levers on all of my ducatis and no problem...maybe some adustment needed
April 11, 2016, 04:07:51 AM »
They can make great stuff (when they want to).
samuraibiker
but it goes to 11
April 12, 2016, 02:06:01 AM »
mr freezer...hmmm... did you adjust the screw that pushes the pin into the master cylinder? if so, all the way in is better?
the levers look fantastic and it`s a shame to have them sitting in a drawer in the garage....
regards
mike
SpikeC
Spike in PDX
April 13, 2016, 09:59:55 AM »
I fitted a set of the folding version of those and they worked fine. I was bothered by the looseness of the joints, though, so after scraping one up a bit (it still worked fine) I replaced them with a set of CRGs. Functionally the same, although the new ones are more aesthetically satisfying!
Spike Cornelius
PDX
2008 Bimota DB5R woo-Hoo!
1965 T100SC
April 13, 2016, 10:16:34 AM »
Quote from: samuraibiker on April 12, 2016, 02:06:01 AM
regards
mike
You need to adjust that screw so there is 1.5-2 mm. free play. Less and clutch slippage can happen.
samuraibiker
but it goes to 11
April 14, 2016, 01:07:59 AM »
sorry but do you mean free play before engaging the levers so that ` at rest` there is such play before putting any pressure on the pins that go into the master cylinders?
Omnipotent Potentate
Personal Pretext
April 14, 2016, 09:43:52 AM »
Free play - the amount of pull travel before the lever actually starts acting on the piston of the Master.
April 14, 2016, 12:04:09 PM »
i have them on 2 bikes, one going on about 4 years. zero problems.
people ask if they are CRG, I say "yes.. Chinese Reproduction Group"
April 14, 2016, 12:19:18 PM »
2WheelsFTW
May the torque be with you
April 19, 2016, 01:48:07 PM »
I can personally contribute to this conversation.
Installed some of these a while back while installing a new clutch slave and oil change (They were CRG knock off's)...Long story short, even with proper clutch lever adjustment and bleed, there was still slip after the install. Now I was only experiencing slip at max torque and at hard shifting. I can only imagine the geometry of these Chinese levers isn't exactly right.
So after a bit of confusion and frustration, I say "Why not put the old levers back on?". I mean why not right?...well sure as shit that fixed my clutch slip. Go figure.
Drink Beer. Ride Motorcycles.
