January 01, 2025, 08:28:26 AM
Please Help
How to change a clutch cover
Topic: How to change a clutch cover (Read 1634 times)
HillbillyOzMonster
April 21, 2016, 01:10:19 PM »
So i took off what i believe to be my clutch cover yesterday and it appears to be a single moulded. like this pic
https://www.google.com.au/search?q=ducati+monster+clutch+covers&client=safari&rls=en&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwigtIO10aDMAhUDqqYKHWMPAtsQsAQIHg&biw=1440&bih=838#imgrc=HiPQmigAz3sowM%3A
I want to change this so i can use mods as seen in the pics below. Can some one please help.
Re: How to change a clutch cover
April 21, 2016, 01:13:51 PM »
You have a wet clutch that runs in oil. You can't change it to a dry cover without also doing a dry clutch conversion...
or take the easier, and possibly less expensive, route of changing to a 900, or similar, engine that uses a dry clutch
TitanMonsterS4R
April 21, 2016, 01:27:36 PM »
Quote from: HillbillyOzMonster on April 21, 2016, 01:10:19 PM
Hey mate - is your 600 a dry clutch or not? Not sure if your model is or not? Single case leads me to believe its a wet clutch but not completely sure.
and DP to the rescue.
April 21, 2016, 01:58:41 PM »
Quote from: TitanMonsterS4R on April 21, 2016, 01:27:36 PM
400, 600, 620, and 750 are wet clutch.
TitanMonsterS4R
April 21, 2016, 02:37:40 PM »
Go 900 mate. You'll love that look and that fantastic unique sound
HillbillyOzMonster
April 21, 2016, 04:13:24 PM »
#so sad atm. Will I be able to use coloured nuts and plates for behind the cover? If so will they be the same irrespective of the clutch being wet or dry?
Feral 859
April 21, 2016, 04:20:50 PM »
You 'could' go this route.
Nibor
insanity far outweighs horsepower
April 21, 2016, 08:55:18 PM »
I know a bloke in Melbourne with a 900 motor for sale
I'd love to get the wet clutch window, but my 750 is the older type with the internal slave, not compatible...
