Will it work on a 2007 S4RS? corse-dynamics-non-slip-eccentric-ducati-chain-tool
Started by dbran1949, April 22, 2016, 08:44:05 PM
dbran1949
Does anyone know if there was a change from the 2007 S4RS to the 2008 that would keep this tool from working on the 2007? For some reason the 07 is not listed in the details
http://motowheels.com/i-9377332-corse-dynamics-non-slip-eccentric-ducati-chain-tool-large.html
No difference AFAIK  [thumbsup]
If possible, get one with a longer handle or add one - short handles is asking for bruised/bloody knuckles...
dbran1949
thanks, it's a little tricky searching for these because, it seems, everyone has a different name for them
If the non-slip feature works, maybe length isn't as important to protect your hands. Length would help if the hub is dry and/or sticking.
I guess "ducati chain adjustment tool"
A quick google didn't show any with a longer arm  ???
Quote from: stopintime on April 23, 2016, 02:49:15 PM
Spanner
Quote from: dbran1949 on April 23, 2016, 02:05:26 PM
Its a spanner. but more specifically, its an eccentric spanner. Named that because it is used to adjust the hub which has a hole that's eccentric to its center line.
Anyone with a diameter within reason will work. Shock adjuster spanner would work too if it could fit in that thing area and had a large enough diameter.
Quote from: He Man on April 25, 2016, 02:59:50 PM
That's what I used when I had my S2R. I have a 240sx with Tein coilovers and the ride height adjustment spanners were a perfect fit.
